Problems since ATI Driver installation
Caporegime
12 Mar 2009
I've just upgraded my graphics card this morning to a Radeon 5850, upon unboxing and sticking it in the PC I downloaded the new catalyst drivers from AMD, I think it was version 10.2
Ever since I've had a weird problem in Firefox, it will just occasionally hang and not do anything, catching up about 55 - 60 seconds later, also, if you try and download anything you get the Firefox download manager pop up but the progress of the download doesn't go anywhere, if you click in the download manager it will cause Firefox to stop responding where I can either wait for it to right it's self or I can just go to task manager, stop Firefox and then relaunch it.
Any ideas what might have caused this? I can always reinstall Firefox and see if it still gives the same issues but as I've had no problems before, it leads me to believe the Catalyst drivers are at fault.
