Problems updating iLO2 on ML350 G6
18 Oct 2002
Hi All,
I've got an ML350 G6 that I'm struggling to update the iLO2 software on.
Currently its running 2.29, but whenever I try and apply 2.30 or 2.31 I get the same error message
The firmware image file was rejected.
Possible reasons:
  • The file specified is not iLO 2 firmware
  • The data in the file specified is corrupt
  • The image would downgrade iLO 2 to a level not supported on this host
  • The firmware in the file has an invalid digital signature
    Please check the file name and try again.
This occurs after it does the whole 'uploading firmware to flash' progress bar. Using a Windows 10 machine that views the iLO2 Webpage in Internet Explorer.
Has anyone ever had this before?
Aha - sorted it.
The place I was, acquiring, the iLO software from had given a method of extracting the BIN files using 7-zip.
For 2.30 and 2.31 you have to do the same action again on the initally extracted file. Doh !
