Problems updating Peerguardian
Man of Honour
12 Jan 2003
UK
does anyone else have the same issue that if you leave PG running, it cant seem to auto update the blocklists? It just gives "error contacting URL" message and doesnt update some of the lists as scheduled. you can get round it by disabling PG temporarily and manually updating the lists, then re-enabling PG afterwards.
it's a bit of an annoying workaround though, is there a better way to do it or fix this issue?
thanks
Methinks the ip of the update server must be in your block lists somewhere
Switch on show blocked connections , try an update and then see what ip is being blocked then remove it from the lists , sorted :-)
I have found if you disable peer guardian and delete all the lists in the lists folder and try to update that tends to work....
The auto update doesn't work on mine either. Unless I reboot then it check at startup, otherwise I have to remember every few days to do a manual update.
