problems with 3 monitor - Resolution etc - grateful for help!
29 Aug 2008
London
Hello OCUK Forum
I was hoping if you could help me.
So i run 3 monitors at the moment.
U3011
U2515 x 2
Resolution on the U3011 is at 2560 * 1600 and the resolution on both the U2515 is 2560 * 1440
The resolution on the U2515's are maxed but everything on it is very fuzzy. I've tried restarting the PC, unplugging and replugging but to no avail.
Would you have any suggestions on this?
Kindest Regards
Sam
So I'm making a couple of assumption here.
1) Your running windows 8/8.1/10
2) The issue effects text and borders of windows mainly.
If that's the case then your looking for "Let me choose one scaling level for all my displays" in control panel, under display settings. Uncheck this option and see if it makes any difference (takes a log off/log on to apply).
Hi mate that's brilliant! I've switched it down to 100% instead of 125% by default! yes its smaller but it looks much better!
thanks again pal
Sam
