- 9 Jun 2004
- UK
Hello,
I've had my 360 running through HDMI on my Samsung HDTV for months now without a hitch. However, in the last few days I've been getting a bit of "interference" on the screen.
Along the bottom of the screen, around an inch up, I'm getting the occasional flash of what I can only describe as interference in a broken line across the entire screen. Occasionally it appears elsewhere on the screen. There is nothing wrong with the TV when I'm watching Freeview or playing my 360/Wii through component etc. Just with the 360.
Is this likely to be a fault with the 360, with my TV's HDMI ports (it happens in both HDMI ports by the way), or with my HDMI cable?
I'd like to add that my HDMI cable is a 10 quid job from B&Q, although I'm told this shouldn't affect the quality of the image, perhaps it has worn itself out a bit quicker than an expensive one would? If the HDMI cable was faulty, would this sort of thing happen or would it just not work at all?
Any ideas?
Thanks
Any ideas?
Thanks
