I'm having a problem with my Hauppauge Nova-T 500 dual freeview DVB tuner card.
Every couple of days it will completely loose the tv signal. Rescanning finds the channels but it won't tune to any of them. Rebooting doesn't fix it. It won't work in either mce or the hauppauge wintv 2000 tv viewing software.
I'm using the latest driver, and i've done several driver updates and the problem still happens, intermittently.
I know its not my tv signal as i have a built in tuner in the tv and if i move the aerial over to that it works fine, every time.
The only way to fix it seems to be to leave the pc off for a while.
Any ideas what it could be?
I've seen this card recommended lots on here, indeed i've recommended it myself a few times, so there must be a few around... has anyone else had problems like this?
The other problem i have with it is it can't pick up channel 5, but the tuner in the tv can... any ideas why this could be?
Thanks
Thanks
