- 22 Mar 2008
I knew that the fitting design of this heatsink was not the best however for the money and the reviews included i thought that it could not be as bad as the intel fitment.
However i was wrong, its just as bad, i am currently having problems getting the heatsink to fit properly, it does work and my temps currently run at about 35 degrees however this is stilll quite high.
I am wondering if anyone else has experienced problems with fitting this cooler, and however they have eradicated this problem, is it just a case of playing around with the cooler and applying brute force? ^^
Thanks
Thanks
