OK, I had a chance to look at my Dad's Acer X243HQ LCD over the weekend and that looked much the same, with a full-screen of orange darker at the top then the rest of the screen and flickering of text when scrolling, so I'm not sure now that there is anything wrong with my Benq. If this is normal for LCDs, I'm not sure how people put up with them though!
A good example of the flickering can be seen by looking at stripy shirts when scrolling, such as the ones linked to below.
It's probably easiest to observe by scrolling one step at a time with the up and down arrows. It might be described better as pulsing or strobing.
http://www.debenhams.com/webapp/wcs...01_080010185003_-1?breadcrumb=Home~Men~Shirts
http://www.debenhams.com/webapp/wcs...01_080010151345_-1?breadcrumb=Home~Men~Shirts
http://www.debenhams.com/webapp/wcs...01_080010185080_-1?breadcrumb=Home~Men~Shirts
I'm not sure if this page comes up the same every time, but if it shows a red shirt bottom left, a blue one bottom right and a black one above that, the problem's particularly noticeable as all three pulse.
http://www.debenhams.com/men/shirts..._18664_18528_128764_ms}&catalogId=10001&pns=y
I've also noticed that on that page PCM2 pointed me to
http://www.lagom.nl/lcd-test/viewing_angle.php when looking at the Lagom text, it turns bright red momentarily whilst scrolling, which isn't mentioned as a common problem on there, so probably shouldn't be happening!
A similar thing happens with the bottom left box on
http://www.atrise.com/lutcurve/ above the text "If you see color tones on the image above", which is almost grey but when scrolling the colours come up quite intensely.
Incidentally, I used Lutcurve to calibrate my monitor and found it pretty handy. I didn't use it's controls to calibrate, as then I'd need it loaded all the time, but running the Benq in Standard mode, I got the blacks and whites about right with Brightness and Contrast both at 30.
On the Gamma screen, I couldn't seem to get that right using the Benq's colour controls, so I've left that on Normal and in Catalyst Control Centre, on the Color tab, dropped the Gamma down to 0.75, which gets it pretty close.
