- 23 Aug 2007
Hi all.
I had a mot done last week and also the fork seals done at the same time.
Today I checked the bike over just to give a clean up and the left fork seal leaking.
But the worst thing the bike has this bad knocking when you push down on the handle bars.
It looks like the front disks are moving but I was told by my friend that they should not of had to do anything to the disks in order to do the fork seals?
I am sure the knocking would be an mot fail so if it was there before ( it was not) then they would have charged me to get that fixed like they did with a broken light switch.
They are coming to pick the bike up tomorrow but I got a bad feeling they have broken something and will try wiggle out of fixing it
