cloak
cloak
I'm having a strange problem with my new build the problem is that when i start the pc all the fans run everything in the pc is on but the monitor comes on and then goes back in standby on signal detected.This also happens when i reboot from software download etc.Things i have done is changed the psu,graphics card the memory the case the monitor even the hard drive but it still does all the same.Have sent back the motherboard cpu and memory and tested ok.I have the ASUS M4A79XTD EVO motherboard and a AMD 11 X4 955 cpu and have but it down to one of those 2 things and its the only things i havnt changed....i have tried everything as you see above even tried to clear rtc ram and even taken out the battery any ideas would be very gratful
Cloak is offline Reply With Quote
