Problems with coh
11 Apr 2003
Notts
Hi all, I keep getting Your connectio to relic has been lost messages, and also when trying to play with a friend whenever we lose a round im unable to rejoin their room, and vice versa saying cannot connect to all people, we know its not our connections or we would not be able to play together at all.... ta
Go here.
It is a very common issue with CoH, Relic are using a bit of software for their online system that's a bit flaky and doesn't like the way some routers work.
There'll probably be a fix, but you'll have to post up on the forum with various log files from CoH and your computer - a very helpful guy called Uberjumper is the resident forum tech guru and will sort you out, he did for me :)
