Hi guys. Spec as in sig.
I'm having real problems clocking my system to 300fsb let alone some of the uber clocks some are getting and i think it might be my ram.
Everything set to stock bar the memory.
Memory set to +3 volts ( it reboots at anything higher), on a *3 mem ratio which is 800mhz at 4,4,4,12( this is what it should be able to run at standard).
When i run sp2004 on the mem test, it reboots the system before two minutes are up every time.
If i put it to *2.5 at 667 it will run forever. I would struggle to run memtest cos i haven't fitted a floppy. I could do if it's the best test to run tho.
I have swapped the modules over but not to the extent i'm sure you'll probably be asking me to.
Any help really appreciated.
Regards
Jobe
Regards
Jobe
