Baically i have done a lot of reasearch on overclocking. I gave my first overclock ago earlier today but with problems. First here are the componets im using:
Gigabyte GA-965G-DS3 mobo
C2D E6400
Antec Freezer 7 Pro
Antec nine hundred gaming case.
All off these components i chose for overclocking. I started off by updating my BIOS to the latest stable BIOS. Now i have gone into the BIOS to start the overclock. At first i have enabled CPU host clock control and then set a mhz freqency of a very small increase to 280. I then stumped the PCI-Freq to 100 as not o be effected by overclock. lastly i set the memory multiplyer to 2.5 just to ensure that memory speeds do not interfier with overclock. At this point i have not adjusted the CPU voltage. once doing this i save the settings and try to boot which is unsucseful and resets the BIOS. I did the same with a clock rate of 270 and this is saved.
I cannot work out why i may be having this problem. Help would be greatly appreciated.
C2D E6400
Antec Freezer 7 Pro
