problems with firefox 2.0.0.11
29 Oct 2003
Perivale, London
Hi,
when ever i click on one of my bookmarks it sometimes takes about 10 seconds or more and then come up with "server not found" but if i click on the "try again" it will load now this dose not happen on every bookmark i have but its on most now and i am getting fed up with it.
would any of you wise men have any ideas as to why its doing this.
i have re-installed firefox but still the same.
ipconfig /flushdns will flush Windows' DNS cache, but the problem might not be your machine storing out of date DNS entries.
should i still try flushing the DNS cache then ?
i have setup a new profile and its still the same i click on a bookmark and nothing for about 10 to 15 seconds then a message "sever not found"
Ideally you need to try sites that you haven't tried already - if it is a DNS issue, once you've got a working result, Windows will hold onto it.
right i tried IE7 and typed in google and it didn't work then typed ocuk and that didn't work as well i then closed IE7 and typed in ocuk and again Internet Explorer cannot display the webpage
try opening a command prompt and typing nslookup. Then at the > type in the site you want to resolve e.g www.cisco.com. You should then get an answer from your dns server - try this s few times and see if you get the same values returned each time
C:\Users\Tony>nslookup
Default Server: UnKnown
Address: 192.168.0.1:53
> www.itv-f1.com/
Server: UnKnown
DNS request timed out.
timeout was 2 seconds.
*** Request to UnKnown timed-out
> www.itv-f1.com/
Server: UnKnown
> www.ebay.co.uk
Server: UnKnown
Non-authoritative answer:
Addresses: 66.135.210.64, 66.135.200.16
Aliases: www.ebay.co.uk
> www.ebay.co.uk
Server: UnKnown
> www.overclockers.co.uk/
Server: UnKnown
*** UnKnown can't find www.overclockers.co.uk/: Non-existent domain
Server: UnKnown
Server: UnKnown
Server: UnKnown
> www.play.com/
Server: UnKnown
> www.play.com/
Server: UnKnown
*** UnKnown can't find www.play.com/: Non-existent domain
just done these dose this mean anything ?
Assuming 192.168.0.1 is your router, it's either doing a crap job of playing DNS proxy, or your ISP's DNS servers are buggered. As I suggested, try switching over to using OpenDNS.
