problems with first build
20 Mar 2005
Leicester
ok getting a few problems on my new build
BSOD with an PFN LIST CORRUPT error
google suggested a memory problem or driver problem
ran memperfect and it showed memory was ok, but backed the speed off from 1666 to 1333mhz just to be on the safe side,
tried driver verifier (windows 7 built in version) and it just kept crashing and BSOD again this time saying HIDCLASS.SYS was the problem. I believe this is to do with input devices ie keyboard and mouse
booted to safe mode and turned off driver verifier then rebooted and windows is running ok now,
however my monitoring software is showing some irregularites, ive circled and linked them so you can see the differences
which one is right? system isnt overclocked.
and any ideas how to solve the HIDCLASS.SYS crash? checked for updated drivers for keyboard and mouse but have all the latest ones
EDIT : system specs in sig, mobo running firmware 1204
