problems with formating
6 Jul 2006
England, Stafford
hiya
i am just about to format my bro computer and instatal windows xp again, the computer has to harddrives one 20gb and a 60gb i am going to put xp on the 20 gb, what i am wanting to know is, should i format the 60gb driver in window before or after i put window back on, i will be doing this useing window formater :)
thx for the help
Can just format the 60GB drive afterwards from inside Windows XP drive management if you aren't using it for the Windows install.
