I've just bought and assembled a Gigabyte ga-p35c-ds3r, Pentium E2200 and 2Gig of OCZ ram.
When i turned it on for the first time (and everytime since!) all i get is a black screen (no signal) so it won't post & get to the bios screen
There are no error beeps unless I purposely remove the ram etc. I've also tried a second gfx card just in case that is at fault but it's not. Both gfx cards work in my other machine.
The cpu fan does spin up as do the HD's so power is getting around the board. I have made sure the 20 + 4 pin (split 24 pin) plus the extra 4 pin for the cpu are plugged in. I've also checked the psu in my other machine and it's also working fine.
I was told by ****** staff that it could be my ram not being compatable with the board or it could be the cpu borked. Unfortunately I can't test the cpu as my other comp is socket 939 athlon.
Any thoughts on this? I've reset the cmos and nothing changes.
Thanks in advance
Thanks in advance
