Problems with HTPC
18 Oct 2002
Current Spec is
E8200
4x1GB of OCZ DDR2 1066 (the sli stuff that was on offer the other week)
Gigabye P35 DS3R
ATi 2600 PRO
1x160 Gig Samsung SATA (Boot)
4x500 Gig Samsung SATA F1's (RAID 5 Storage Array)
Corsair 650W PSU
Creative Xfi Soundcard
Hauppage HVR 1300
Windows Vista Ultimate
Riteo, built this pc last weekend and all appeared to be well until I put in 2 extra sticks of ram (going from 2 - 4 GB) Since then the machine kept randomly black screening in windows and rebooting. I've reinstalled vista (32) and now I keep getting Driver IRQ Less than equal blue screens.
I'm current running Memtest 86+ V2.01 from a bootable disc, but so far its 39% through and no errors as yet.
Any ideas what I need to do here please?
Many Thanks
What memory voltage are you running, you might need to up the MCH voltage up a little bit as your using all slots.
Rob
wait a second take out all 4 sticks of ram and compair the pcb color (the board colour) are they all green, all black or 2 of each
Rob
I tried upping just the Memory 'overvolt' settings in the bios, but it didnt seem to help much.
Apologies for being a shade retarted, but what is the MCH voltage, where is it in the bios, and what do I need to up it to.
Reference the PCB colours, they are all green with black heatspreaders on.
Edit - For Clarity, the Ram is - http://www.overclockers.co.uk/showproduct.php?prodid=MY-082-OC&groupid=701&catid=8&subcat=817 - and the Mobo is http://www.overclockers.co.uk/showproduct.php?prodid=MB-088-GI&groupid=701&catid=5&subcat=913
i have that ram and had to install service pack 1 before i got full stability with that amount of ram, make sure you have it installed
Hi, the MCH is your northbridge, as your running will all dimm slots in use it puts extra stress on your northbridge by upping the voltage by .1 or .2 does help in some cases.
I'm not sure were this setting is but on my X38 DS5 it's on the same screen were I setup my FSB and cpu voltages.
Also have check on your memory timmings.
Hopefully the above should be of some help :p
Rob :)
Rob :)
Thanks for your reply, I've just passed Memtest86+ on the first pass.
Timmings are currently set at 5-7-7-24, which is what the mobo set it as for stock. I'll tweak the ram up .2 and the northbridge by .2 and see how we get on.
Thank you for your help
riteo, I did that, and for a longer period, it was more stable.
got into windows, started to install the ATi drivers and it failed, ran prime 95, and that failed within seconds saying there was a hardware failure....
about a minute after that it then did the Driver IRQ less than or not equal yada yada
Ideas?
Strange, check your BIOS revision to see if there is an update available.
I had a simular problem when I added an extra 2gig to my IP35 Pro, I had to do a CMOS reset and start from scratch upping my voltages and changing my timmings.
Try doing the above if you have not done so already, and set the timmings and voltage as recommended, should be a sticker showing the voltage and timmings on your memory modules, you might also need to up the MCH voltage bit more than you have done already.
Rob
I’m sorry but OCUK have got their product description wrong. The Gigabyte GA-P35-DS3R has four DDR2 memory slots; up to 8GB of DDR2 1066/800/667 MHz memory can be installed. Its the Gigabyte GA-P35C-DS3R (Socket 775) PCI-Express Motherboard that has both DDR2, DDR3 support.
ok the problem is that they run at different voltages ring up ocuk and they will swap the black ones for newer green ones (thats why i love ocuk)
i just rung them up and they organised for me to send the item back
i think the person who helped me was called adam
Not had as much luck. I'll have a chat with Gibbo on MSN and see if he can sort it out for me. Benefits of being freindly with management ;)
why arent you having as much luck?
i was quite annoyed that i had purchased 2 gig of ram one week and then the next week got another two only to be met with a string of bsod's and then to find out that the two versions of ram are not compatible but i was delighted when i rung up that ocuk would replace it with in the next 2 days
good luck !
Not sure, probably not one to discuss on the forums tbh, as to be honest, as long as I get the kit replaced I dont really mind. I'll have a quiet word with the guys I know who work there to ensure there is clarity of process for anyone else who gets into this situation.
