Hi there,
I wonder if someone can help me, I have a 3870X2 and currently experiencing a black screen every time I play a game or do anything graphically intensive.
The system itself has not crashed, I can still hear the music playing on my headphones. The screen just goes black and the fans on my graphics card becomes much louder as it suddenly starts going really fast.
The idle temperature is 62 degrees, is this normal?
I have also used driver cleaner to remove the old ati drivers and try a refresh of the newer 8.12 drivers with no difference made at all.
Does anyone have any suggestions what I should do to fix the problem?
I ran a test using Video Card Stability from http://freestone-group.com/
and I ran the test for 4 minutes and no problems but the catalyst control center (CCC) is showing the temps of GPU at 73 degrees and not dropping.
I will try the benchmark to see what happens.....
So the benchmark worked okay... not a problem so far... I guess it's not so graphically intensive to cause the black screen. But the problem still occurs in every game I play.
Here are my system specs if you need it:
Vista Ultimate 64bit edition
Intel 8500 CPU
BFG 680i mobo
2GB low latency OCZ RAM (ATI supported)
3870X2
650W PSU
So trying the test (not benchmark) again, I now am experiencing temps of 80 degrees while the test is running the activity is up to 95%.
I am going to leave the test running for a while....(will check after lunch
After running for over an hour no change. I am going to download 3D Mark and see if I can install it and test it with that.
Intel 8500 CPU
BFG 680i mobo
3870X2
650W PSU
