Problems with my Corsair vengeance kit.
4 Dec 2008
Sheffield
So I got the 8gb c8 kit to go with my gigabyte p67a-ud7-b3. One stick will post with default timings set manually or via XMP and one will not. Both together will not. I have tried the possibly faulty stick in every slot and no joy. same settings and the other stick works in every slot every time. If I loosen the timings to 9-9-9-24 the dodgy stick posts on it's own and with the other stick.
I've checked the voltages and timings over and over and everything is set correctly.
Could I be missing something or should I RMA? I'm guessing yes as they should share the same tolerances.
