- 18 Mar 2011
- East London.
Its been running fine till about 2 weeks ago when all of a sudden the screen would go blank. I thought it might me a video card problem so tried another video card which i had at the time but the fault still happened. I tried another monitor and the fault i was getting did not occur.
From what i can gather on my U3011 the video signal is present but it maybe the back light which is causing the problem.
When the screen does go blank if i give it a nudge the light comes back on but then may go off or flash on and off randomly for a bit. This fault occurs for all the connections..dvi, hdmi, displayport etc.
anyone have any idea as to what it could be, repairs etc.
Its not under warranty.
thank you
thank you
