Hi,
I just bought the Belkin adsl wireless g router that ocuk sell for £15. Now I have got it all connected to my net connection no problems, and I can connect to it by wire no problems. But when I try to sort out the wireless it doesn't work.
I have turned off any wep etc and it now works with the wireless. So I have tried both WPA-PSK and WEP 64-bit. Both of these come out with the same problem of being able to initially connect then a few minutes later it drops the connection and does not allow you to reconnect, but the router can still be seen on the network.
I have made sure that it isnt conflicting with channel number also just in case that is an issue. Also this runs true for all 7 different devices I have tried, one also using a Belkin wireless g pci card.
Any ideas for anything I can try?
