- 11 Jan 2006
Good Afternoon all,
Just wanted to ask if anyone had any ideas for my problem,
OK Specs
AMD 4200+ 2.2GHz
3GB Geil RAM
Gigabyte K8N Pro-SLi
Samsung Spinpoints x2 160GB
Sapphire HD2900XT
When i push the FSB past a certain point the computer cycles on a restart for ages then it will begin and load windows.
In detail, After about 210Mhz the computer loads the BIOS, checks the CPU, memory and then tells me my FSB is higher than it should be, at the next point it should detect the HDD and DVD drives, ie (Detecting IDE Devices) IF this does not happen soon the computer restarts and goes the the whole thing again and again, for about 10 mins, maybe more, then when it states "Detecting IDE devices" it will then allow me to load windows. I did have it the FSB about 227 i think the cpu was at about 2.47Ghz stable when windows loaded.
So I know it works but I want it to load first time. Any advice would be a help.
Thanks guys.
OK Specs
AMD 4200+ 2.2GHz
3GB Geil RAM
Sapphire HD2900XT
Thanks guys.
they may work at certain FSB speeds where as if you lower the FSB my even 1mhz they may throw a wobbly! Its about finding the 'right' setup so lots of trial and error
