- 7 Aug 2020
Hi I've been having problem with my internet dropping a few times a day since i bought this router last week.
This is what I usually see in logs -
Aug 7 01:11:08 acsd: acs_set_chspec: 0x1005 (5) for reason APCS_CSTIMER
Aug 7 01:24:30 acsd: eth6: selected_chspec is 0x1003 (3)
Aug 7 01:24:30 acsd: eth6: Adjusted channel spec: 0x1003 (3)
Aug 7 01:24:30 acsd: eth6: selected channel spec: 0x1003 (3)
Aug 7 01:24:31 acsd: eth6: selected_chspec is 0x1003 (3)
Aug 7 01:24:31 acsd: eth6: Adjusted channel spec: 0x1003 (3)
Aug 7 01:24:31 acsd: eth6: selected channel spec: 0x1003 (3)
Aug 7 01:24:32 acsd: eth6: selected_chspec is 0x1003 (3)
Aug 7 01:24:32 acsd: eth6: Adjusted channel spec: 0x1003 (3)
Aug 7 01:24:32 acsd: eth6: selected channel spec: 0x1003 (3)
Aug 7 01:24:33 acsd: eth6: selected_chspec is 0x1003 (3)
but today it happened for a long time, couldnt access the user interface or anything and the logs are abit nuts.
May 5 06:05:12 kernel: klogd started: BusyBox v1.24.1 (2020-04-30 22:34:39 CST)
May 5 06:05:12 kernel: Linux version 4.1.51 (gitserv_asus@asuswrt-build-server) (gcc version 5.5.0 (Buildroot 2017.11.1) ) #4 SMP PREEMPT Thu Apr 30 23:27:31 CST 2020
May 5 06:05:12 kernel: CPU: AArch64 Processor [420f1000] revision 0
May 5 06:05:12 kernel: Kernel command line: coherent_pool=4M cpuidle_sysfs_switch pci=pcie_bus_safe rootwait
May 5 06:05:12 kernel: Virtual kernel memory layout:
May 5 06:05:12 kernel: vmalloc : 0xffffff8000000000 - 0xffffffbdffff0000 ( 247 GB)
May 5 06:05:12 kernel: vmemmap : 0xffffffbe00000000 - 0xffffffbfc0000000 ( 7 GB maximum)
May 5 06:05:12 kernel: 0xffffffbe00000000 - 0xffffffbe00e00000 ( 14 MB actual)
May 5 06:05:12 kernel: fixed : 0xffffffbffabfd000 - 0xffffffbffac00000 ( 12 KB)
May 5 06:05:12 kernel: PCI I/O : 0xffffffbffae00000 - 0xffffffbffbe00000 ( 16 MB)
May 5 06:05:12 kernel: modules : 0xffffffbffc000000 - 0xffffffc000000000 ( 64 MB)
May 5 06:05:12 kernel: memory : 0xffffffc000000000 - 0xffffffc040000000 ( 1024 MB)
May 5 06:05:12 kernel: .init : 0xffffffc0006bd000 - 0xffffffc0006f5000 ( 224 KB)
May 5 06:05:12 kernel: .text : 0xffffffc000080000 - 0xffffffc0006bc204 ( 6385 KB)
May 5 06:05:12 kernel: .data : 0xffffffc0006f6000 - 0xffffffc0007c14c0 ( 814 KB)
May 5 06:05:12 kernel: init_timers: timer_function_timeout virt addr 0xffffffc000710e48
May 5 06:05:12 kernel: creating mapping for reserved memory phys 0x0a600000 virt 0xffffffc00a600000 size 0x00e00000 for dhd0
May 5 06:05:12 kernel: creating mapping for reserved memory phys 0x09800000 virt 0xffffffc009800000 size 0x00e00000 for dhd1
May 5 06:05:12 kernel: creating mapping for reserved memory phys 0x08a00000 virt 0xffffffc008a00000 size 0x00e00000 for dhd2
May 5 06:05:12 kernel: Do not need to create mapping for reserved memory phys 0x0e000000 size 0x02000000 for buffer
May 5 06:05:12 kernel: creating mapping for reserved memory phys 0x0b400000 virt 0xffffffc00b400000 size 0x02c00000 for flow
May 5 06:05:12 kernel: pmc_init
MC using DQM mode
May 5 06:05:12 kernel: Successfully retrieved NVRAM data from dtb
May 5 06:05:12 kernel: cfe-v^A: 1.0.38-163.181
May 5 06:05:12 kernel: CPU1: Booted secondary processor
May 5 06:05:12 kernel: CPU2: Booted secondary processor
May 5 06:05:12 kernel: CPU3: Booted secondary processor
May 5 06:05:12 kernel: Broadcom Logger v0.1
May 5 06:05:12 kernel: skb_free_task created successfully with start budget 256
May 5 06:05:12 kernel: net_dev_init: process_backlog_timeout virt addr 0xffffffc0007b3570
May 5 06:05:12 kernel: gbpm_do_work scheduled
May 5 06:05:12 kernel: ^[[0;34mBLOG v3.0 Initialized^[[0m
May 5 06:05:12 kernel: BLOG Rule v1.0 Initialized
May 5 06:05:12 kernel: Broadcom IQoS v1.0 initialized
May 5 06:05:12 kernel: Broadcom GBPM v0.1 initialized
May 5 06:05:12 kernel: >>>>> For primary mtd partition rootfs, cferam/vmlinux.lz mounted as JFFS2, vmlinux fs mounted as UBIFS <<<<<
May 5 06:05:12 kernel: Secondary mtd partition rootfs_update detected as JFFS2 for cferam/vmlinux source and UBIFS for vmlinux filesystem
May 5 06:05:12 kernel: setup_mtd_parts: misc indx 2 name misc3 nvram configured size 1
May 5 06:05:12 kernel: setup_mtd_parts: name misc3 configured size 0x00100000 offset 0xF600000
May 5 06:05:12 kernel: setup_mtd_parts: misc indx 1 name misc2 nvram configured size 63
May 5 06:05:12 kernel: setup_mtd_parts: name misc2 configured size 0x03f00000 offset 0xB700000
May 5 06:05:12 kernel: setup_mtd_parts: misc indx 0 name misc1 nvram configured size 8
May 5 06:05:12 kernel: setup_mtd_parts: name misc1 configured size 0x00800000 offset 0xAF00000
May 5 06:05:12 kernel: Creating 11 MTD partitions on "brcmnand.0":
May 5 06:05:12 kernel: 0x000000620000-0x000005800000 : "rootfs"
May 5 06:05:12 kernel: 0x000005dc0000-0x00000af00000 : "rootfs_update"
May 5 06:05:12 kernel: 0x00000f700000-0x00000ff00000 : "data"
May 5 06:05:12 kernel: 0x000000000000-0x000000100000 : "nvram"
May 5 06:05:12 kernel: 0x000000100000-0x000005800000 : "image"
May 5 06:05:12 kernel: 0x000005800000-0x00000af00000 : "image_update"
May 5 06:05:12 kernel: 0x000000100000-0x000000600000 : "bootfs"
May 5 06:05:12 kernel: 0x000005800000-0x000005da0000 : "bootfs_update"
May 5 06:05:12 kernel: 0x00000f600000-0x00000f700000 : "misc3"
May 5 06:05:12 kernel: 0x00000b700000-0x00000f600000 : "misc2"
May 5 06:05:12 kernel: 0x00000af00000-0x00000b700000 : "misc1"
May 5 06:05:12 kernel: brcmboard registered
May 5 06:05:12 kernel: brcmboard: brcm_board_init entry
May 5 06:05:12 kernel: print_rst_status: Last RESET due to POR reset
May 5 06:05:12 kernel: print_rst_status: RESET reason: 0x00000000
May 5 06:05:12 kernel: DYING GASP IRQ Initialized and Enabled
May 5 06:05:12 kernel: map_hw_timer_interrupt,127: interrupt_id 22
May 5 06:05:12 kernel: map_hw_timer_interrupt,127: interrupt_id 23
May 5 06:05:12 kernel: map_hw_timer_interrupt,127: interrupt_id 24
May 5 06:05:12 kernel: map_hw_timer_interrupt,127: interrupt_id 25
May 5 06:05:12 kernel: Registering button 0 (ffffffc00080e2c8) (bpGpio: 00008004, bpExtIrq:00000000 (0))
May 5 06:05:12 kernel: extIrqIdx:0, gpioNum:4 ACTIVE LOW
May 5 06:05:12 kernel: Registering button 1 (ffffffc00080e388) (bpGpio: 0000801d, bpExtIrq:00000001 (1))
May 5 06:05:12 kernel: extIrqIdx:1, gpioNum:29 ACTIVE LOW
May 5 06:05:12 kernel: Registering button 2 (ffffffc00080e448) (bpGpio: 0000801b, bpExtIrq:00000001 (1))
May 5 06:05:12 kernel: extIrqIdx:1, gpioNum:27 ACTIVE LOW
May 5 06:05:12 kernel: genirq: Flags mismatch irq 36. 00000000 (brcm_36) vs. 00000000 (brcm_36)
May 5 06:05:12 kernel: request_irq failed for irq=36 (brcm_36) retval=-16
May 5 06:05:12 kernel: registerBtns: Button index 3 out of range (max 3)
May 5 06:05:12 kernel: bcm_i2c: i2c bus 0 polling mode (mod_abs_gpio 255)
May 5 06:05:12 kernel: BPM: tot_mem_size=1073741824B (1024MB),
May 5 06:05:12 kernel: bcm_i2c: bus 0: module inserted
May 5 06:05:12 kernel: buf_mem_size <15%> =161061270B (153MB), num of buffers=57195, buf size=2816
May 5 06:05:12 kernel: Broadcom BPM Module Char Driver v0.1 Registered<3004>^[[0m
May 5 06:05:12 kernel: ^[[0;34m[NTC bpm] bpm_module_init: tot_mem_pool=2487 mem_idx:2487^[[0m
May 5 06:05:12 kernel: ubi0: attaching mtd0
May 5 06:05:12 kernel: ubi0: scanning is finished
May 5 06:05:12 kernel: ubi0: attached mtd0 (name "rootfs", size 81 MiB)
May 5 06:05:12 kernel: ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
May 5 06:05:12 kernel: ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
May 5 06:05:12 kernel: ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
May 5 06:05:12 kernel: ubi0: good PEBs: 655, bad PEBs: 0, corrupted PEBs: 0
May 5 06:05:12 kernel: ubi0: user volume: 1, internal volumes: 1, max. volumes count: 128
May 5 06:05:12 kernel: ubi0: max/mean erase counter: 1/0, WL threshold: 4096, image sequence number: 1382805210
May 5 06:05:12 kernel: ubi0: available PEBs: 0, total reserved PEBs: 655, PEBs reserved for bad PEB handling: 13
May 5 06:05:12 kernel: ubi0: background thread "ubi_bgt0d" started, PID 70
May 5 06:05:12 kernel: UBIFS (ubi0:0): UBIFS: mounted UBI device 0, volume 0, name "rootfs_ubifs", R/O mode
May 5 06:05:12 kernel: UBIFS (ubi0:0): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
May 5 06:05:12 kernel: UBIFS (ubi0:0): FS size: 79613952 bytes (75 MiB, 627 LEBs), journal size 9023488 bytes (8 MiB, 72 LEBs)
May 5 06:05:12 kernel: UBIFS (ubi0:0): reserved for root: 0 bytes (0 KiB)
May 5 06:05:12 kernel: UBIFS (ubi0:0): media format: w4/r0 (latest is w4/r0), UUID 5E637D24-1DEF-4CDD-B299-E6DD8A19D32B, small LPT model
May 5 06:05:12 kernel: jffs2: notice: (93) jffs2_build_xattr_subsystem: complete building xattr subsystem, 0 of xdatum (0 unchecked, 0 orphan) and 0 of xref (0 dead, 0 orphan) found.
May 5 06:05:12 kernel: jffs2: notice: (156) jffs2_build_xattr_subsystem: complete building xattr subsystem, 0 of xdatum (0 unchecked, 0 orphan) and 0 of xref (0 dead, 0 orphan) found.
May 5 06:05:12 kernel: wlcsm: module license 'Proprietary' taints kernel.
May 5 06:05:12 kernel: Disabling lock debugging due to kernel taint
May 5 06:05:12 kernel: bm_base_addr 0xffffffc00e000000, size 33554432, bm_base_addr_phys 0x000000000e000000
May 5 06:05:12 kernel: fm_base_addr 0xffffffc00b400000, size 46137344, fm_base_addr_phys 0x000000000b400000
May 5 06:05:12 kernel: RDP Physical address=0x82200000 Virtual address = 0xffffff8000b80000
May 5 06:05:12 kernel: configure_runner: NATC keysize 0x100070 key element size 16 contextsize 0x400000 context element size 64
May 5 06:05:12 kernel: ++++Runner gso_desc_pool created successfully
May 5 06:05:12 kernel: rdd_init_params.runner_nat_cache_key_ptr=0xffffffc00bd00000
May 5 06:05:12 kernel: rdd_init_params.runner_nat_cache_context_ptr=0xffffffc00b400000
May 5 06:05:12 kernel: rdd_init_params.runner_context_cont_ptr=0xffffffc00b800000
May 5 06:05:12 kernel: FPM_BPM phy_addr 0x82c30000,virt_addr 0xffffff8000862000
May 5 06:05:12 kernel: RDP PKT memory = 32MB : Max Possible Bufs <16384> of size <2048>; Allocating <15360> bufs; RDP enum <5>
May 5 06:05:12 kernel: brcmchipinfo: brcm_chipinfo_init entry
May 5 06:05:12 kernel: NBUFF v1.0 Initialized
May 5 06:05:12 kernel: npe_max_ent<32768> npe_ht_ent<8192>
May 5 06:05:12 kernel: ^[[0;36;44mTotal # of labels = 68^[[0m
May 5 06:05:12 kernel: ^[[0;36;44mInitialized fcache state^[[0m
May 5 06:05:12 kernel: ^[[0;36;44mBroadcom Packet Flow Cache Char Driver v4.0 Registered<3002>^[[0m
May 5 06:05:12 kernel: fc_timer_task created successfully
May 5 06:05:12 kernel: Created Proc FS /procfs/fcache
May 5 06:05:12 kernel: ^[[0;36;44mBroadcom Packet Flow Cache registered with netdev chain^[[0m
May 5 06:05:12 kernel: ^[[0;36;44mBroadcom Packet Flow Cache learning via BLOG enabled.^[[0m
May 5 06:05:12 kernel: ^[[0;35m[FHW] pktDbgLvl[0xffffffbffc3f9f88]=0^[[0m
May 5 06:05:12 kernel: ^[[0;34m[FHW] fhw_construct: ^[[0m
May 5 06:05:12 kernel: ^[[0;36;44mInitialized Fcache HW accelerator layer state^[[0m
May 5 06:05:12 kernel: flwStatsThread created. numFlwsPerPoll 546 maxFlwIdx 16383
May 5 06:05:12 kernel: ^[[0;36;44mFcache Pathstats created^[[0m
May 5 06:05:12 kernel: ^[[0;36;44mConstructed Broadcom Packet Flow Cache v4.0^[[0m
May 5 06:05:12 kernel: crossbar[0]: Allocated cb_idx=0 int_ep=0
May 5 06:05:12 kernel: crossbar[0]: Add cb_idx=0 ext_ep=0 SERDES:6
May 5 06:05:12 kernel: crossbar[1]: Allocated cb_idx=0 int_ep=1
May 5 06:05:12 kernel: crossbar[1]: Add cb_idx=0 ext_ep=1 GPHY:12
May 5 06:05:12 kernel: crossbar Mux: connect cb_idx:0 int_ep 0 to ext_ep 0
May 5 06:05:12 kernel: crossbar Mux: connect cb_idx:0 int_ep 1 to ext_ep 1
May 5 06:05:12 kernel: Detecting PHYs...
May 5 06:05:12 kernel: 84880 B0 ae02:5159 --> N/A
May 5 06:05:12 kernel: 84881 B0 ae02:5151 --> N/A
May 5 06:05:12 kernel: 84884 B0 ae02:5149 --> N/A
May 5 06:05:12 kernel: 84884E B0 ae02:5169 --> N/A
May 5 06:05:12 kernel: 84885 B0 ae02:5179 --> N/A
May 5 06:05:12 kernel: 84886 B0 ae02:5171 --> N/A
May 5 06:05:12 kernel: 84887 B0 ae02:5145 --> N/A
May 5 06:05:12 kernel: 84888 B0 ae02:5141 --> N/A
May 5 06:05:12 kernel: 84888E B0 ae02:5161 --> N/A
May 5 06:05:12 kernel: 84888S B0 ae02:5175 --> N/A
May 5 06:05:12 kernel: 84891 B0 3590:5091 --> N/A
May 5 06:05:12 kernel: 54991 B0 3590:5095 --> N/A
May 5 06:05:12 kernel: 54991E B0 3590:5099 --> 0x1e
May 5 06:05:12 kernel: 84891L B0 3590:5081 --> N/A
May 5 06:05:12 kernel: 54991L B0 3590:5085 --> N/A
May 5 06:05:12 kernel: 54991EL B0 3590:5089 --> N/A
May 5 06:05:12 kernel: 84892 B0 3590:50a1 --> N/A
May 5 06:05:12 kernel: 54992 B0 3590:50a5 --> N/A
May 5 06:05:12 kernel: 54992E B0 3590:50a9 --> N/A
May 5 06:05:12 kernel: 84894 B0 3590:50b1 --> N/A
May 5 06:05:12 kernel: 54994 B0 3590:50b5 --> N/A
May 5 06:05:12 kernel: 54994E B0 3590:50b9 --> N/A
May 5 06:05:12 kernel: 54991H B0 3590:50d1 --> N/A
May 5 06:05:12 kernel: 54994H B0 3590:50f1 --> N/A
May 5 06:05:12 kernel: Loading firmware into detected phys...
May 5 06:05:12 kernel: Firmware version: Blackfin B0 v01-00-12-2019-06-06
May 5 06:05:12 kernel: Loading firmware into phys: map=0x40000000
May 5 06:05:12 kernel: Halt the phys processors operation
May 5 06:05:12 kernel: Upload the firmware into the on-chip memory
May 5 06:05:12 kernel: ^M0%^M1%^M2%^M3%^M4%^M5%^M6%^M7%^M8%^M9%^M10%^M11%^M12%^M13%^M14%^M15%^M16%^M17%^M18%^M19%^M20%^M21%^M22%^M23%^M24%^M25%^M26%^M27%^M28%^M29%^M30%^M31%^M32%^M33%^M34%^M35%^M36%^M37%^M38%^M39%^M40%^M41%^M42%^M43%^M44%^M45%^M46%^M47%^M48%^M49%^M50%^M51%^M52%^M53%^M54%^M55%^M56%^M57%^M58%^M59%^M60%^M61%^M62%^M63%^M64%^M65%^M66%^M67%^M68%^M69%^M70%^M71%^M72%^M73%^M74%^M75%^M76%^M77%^M78%^M79%^M80%^M81%^M82%^M83%^M84%^M85%^M86%^M87%^M88%^M89%^M90%^M91%^M92%^M93%^M94%^M95%^M96%^M97%^M98%^M99%^M100%
May 5 06:05:12 kernel: Reset the processors to start execution of the code in the on-chip memory
May 5 06:05:12 kernel: Verify that the processors are running: OK
May 5 06:05:12 kernel: Verify that the firmware has been loaded with good CRC: OK
May 5 06:05:12 kernel: Firmware loading completed successfully
May 5 06:05:12 kernel: NOTE: Using Port Grouping for IMP ports : [ 0 --> 4 ] [ 1, 2 --> 5 ] [ 3, 7 --> 8 ]
May 5 06:05:12 kernel: LAG/Trunking enabled <0x08>
May 5 06:05:12 kernel: Setting SGMII Calibration value to 0xa
May 5 06:05:12 kernel: ### PHY: 5499X series, enable pair swap! ###
May 5 06:05:12 kernel: Unsupported MII type: 0
May 5 06:05:12 kernel: set led mode - firmware control
May 5 06:05:12 kernel: eth0: <Int sw port: 3> <Logical : 03> MAC : D4:5D:64:A4:6A:10
May 5 06:05:12 kernel: Chip Physical Port 10, Cross Bar Port 1, PHY_ID <0x0007f00c:0x0c:On-chip GPHY >
May 5 06:05:12 kernel: eth1: <Ext sw port: 0> <Logical : 08> PHY_ID <0x0007f008:0x08:On-chip GPHY> MAC
4:5D:64:A4:6A:10
May 5 06:05:12 kernel: eth2: <Ext sw port: 1> <Logical : 09> PHY_ID <0x0007f009:0x09:On-chip GPHY> MAC
4:5D:64:A4:6A:10
May 5 06:05:12 kernel: eth3: <Ext sw port: 2> <Logical : 10> PHY_ID <0x0007f00a:0x0a:On-chip GPHY> MAC
4:5D:64:A4:6A:10
May 5 06:05:12 kernel: eth4: <Ext sw port: 3> <Logical : 11> PHY_ID <0x0007f00b:0x0b:On-chip GPHY> MAC
4:5D:64:A4:6A:10
May 5 06:05:12 kernel: eth5: <Ext sw port: 7> <Logical : 15> MAC : D4:5D:64:A4:6A:10
May 5 06:05:12 kernel: Chip Physical Port 9, Cross Bar Port 0, PHY_ID <0x06180006:0x06:On-chip SERDES >
May 5 06:05:12 kernel: PHY_ID <0x0308001e:0x1e:External Cascaded Claus45 EXT3>
May 5 06:05:12 kernel: ===> Activate Deep Green Mode
May 5 06:05:12 kernel: dgasp: kerSysRegisterDyingGaspHandler: bcmsw registered
May 5 06:05:12 kernel: Broadcom Command List Driver v1.0
May 5 06:05:12 kernel: Initialized Runner Host Layer
May 5 06:05:12 kernel: Initialized Runner Unicast Layer
May 5 06:05:12 kernel: Initialized Runner L2 Unicast Layer
May 5 06:05:12 kernel: Initialized Runner Multicast Layer
May 5 06:05:12 kernel: Retrieve num_fhw_path=64
May 5 06:05:12 kernel: ^[[0;36;44mBroadcom Packet Flow Cache HW acceleration enabled.^[[0m
May 5 06:05:12 kernel: Enabled Runner binding to Flow Cache
May 5 06:05:12 kernel: Initialized Runner Protocol Layer (800)
May 5 06:05:12 kernel: Broadcom Runner Blog Driver Char Driver v0.1 Registered <3009>
May 5 06:05:12 kernel: PCIe HCD (impl1)^M
May 5 06:05:12 kernel: core [2] probe^M
May 5 06:05:12 kernel: bcm963xx-pcie: found port [0] GEN2 Core Rev [3.04] with 1 Lanes^M
May 5 06:05:12 kernel: bcm963xx-pcie: Core [2] setting resistor calibration value to 0xa
May 5 06:05:12 kernel: bcm963xx-pcie: core [2] Link UP - [1] lanes, [GEN2] speed^M
May 5 06:05:12 kernel: bcm963xx-pcie: Core [2] Enabled PCIE/UBUS Error Interrupts^M
May 5 06:05:12 kernel: bcm963xx-pcie: Core [2] UBUS Intr [UBUS_LINKUP]^M
May 5 06:05:12 kernel: pci 0000:00:00.0: of_irq_parse_pci() failed with rc=-22
May 5 06:05:12 kernel: pci 0000:01:00.0: of_irq_parse_pci() failed with rc=-22
May 5 06:05:12 kernel: core [0] probe^M
May 5 06:05:12 kernel: bcm963xx-pcie: found port [1] GEN2 Core Rev [3.04] with 2 Lanes^M
May 5 06:05:12 kernel: bcm963xx-pcie: Core [0] setting resistor calibration value to 0xa
May 5 06:05:12 kernel: bcm963xx-pcie: core [0] Link UP - [2] lanes, [GEN2] speed^M
May 5 06:05:12 kernel: bcm963xx-pcie: Core [0] Enabled PCIE/UBUS Error Interrupts^M
May 5 06:05:12 kernel: bcm963xx-pcie: Core [0] UBUS Intr [UBUS_LINKUP]^M
May 5 06:05:12 kernel: pci 0001:00:00.0: of_irq_parse_pci() failed with rc=-22
May 5 06:05:12 kernel: pci 0001:01:00.0: of_irq_parse_pci() failed with rc=-22
May 5 06:05:12 kernel: core [1] probe^M
May 5 06:05:12 kernel: bcm963xx-pcie: found port [2] GEN2 Core Rev [3.04] with 1 Lanes^M
May 5 06:05:12 kernel: bcm963xx-pcie: Core [1] setting resistor calibration value to 0xa
May 5 06:05:12 kernel: bcm963xx-pcie: core [1] Link UP - [1] lanes, [GEN2] speed^M
May 5 06:05:12 kernel: bcm963xx-pcie: Core [1] Enabled PCIE/UBUS Error Interrupts^M
May 5 06:05:12 kernel: bcm963xx-pcie: Core [1] UBUS Intr [UBUS_LINKUP]^M
May 5 06:05:12 kernel: pci 0002:00:00.0: of_irq_parse_pci() failed with rc=-22
May 5 06:05:12 kernel: pci 0002:01:00.0: of_irq_parse_pci() failed with rc=-22
May 5 06:05:12 kernel: ^[[1m^[[34mWifi Forwarding Driver is initialized!^[[0m
May 5 06:05:12 kernel: broadcomThermalDrv brcm-therm: init (CPU count 4 4 4 4)
May 5 06:05:12 kernel: ubi1: attaching mtd10
May 5 06:05:12 kernel: ubi1: scanning is finished
May 5 06:05:12 kernel: ubi1: attached mtd10 (name "misc1", size 8 MiB)
May 5 06:05:12 kernel: ubi1: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
May 5 06:05:12 kernel: ubi1: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
May 5 06:05:12 kernel: ubi1: VID header offset: 2048 (aligned 2048), data offset: 4096
May 5 06:05:12 kernel: ubi1: good PEBs: 64, bad PEBs: 0, corrupted PEBs: 0
May 5 06:05:12 kernel: ubi1: user volume: 1, internal volumes: 1, max. volumes count: 128
May 5 06:05:12 kernel: ubi1: max/mean erase counter: 4/2, WL threshold: 4096, image sequence number: 1091345526
May 5 06:05:12 kernel: ubi1: available PEBs: 0, total reserved PEBs: 64, PEBs reserved for bad PEB handling: 4
May 5 06:05:12 kernel: ubi1: background thread "ubi_bgt1d" started, PID 364
May 5 06:05:12 kernel: UBIFS (ubi1:0): background thread "ubifs_bgt1_0" started, PID 380
May 5 06:05:12 kernel: UBIFS (ubi1:0): UBIFS: mounted UBI device 1, volume 0, name "nvram"
May 5 06:05:12 kernel: UBIFS (ubi1:0): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
May 5 06:05:12 kernel: UBIFS (ubi1:0): FS size: 5840896 bytes (5 MiB, 46 LEBs), journal size 1396736 bytes (1 MiB, 11 LEBs)
May 5 06:05:12 kernel: UBIFS (ubi1:0): reserved for root: 0 bytes (0 KiB)
May 5 06:05:12 kernel: UBIFS (ubi1:0): media format: w4/r0 (latest is w4/r0), UUID 92D70055-D40E-4496-A698-DA48D5E57B93, small LPT model
May 5 06:05:12 kernel: UBIFS (ubi1:0): un-mount UBI device 1
May 5 06:05:12 kernel: UBIFS (ubi1:0): background thread "ubifs_bgt1_0" stops
May 5 06:05:12 kernel: ubi1: detaching mtd10
May 5 06:05:12 kernel: ubi1: mtd10 is detached
May 5 06:05:12 kernel: ubi1: background thread "ubi_bgt1d" started, PID 440
May 5 06:05:12 kernel: UBIFS (ubi1:0): background thread "ubifs_bgt1_0" started, PID 456
May 5 06:05:12 kernel: ubi1: background thread "ubi_bgt1d" started, PID 516
May 5 06:05:12 kernel: UBIFS (ubi1:0): background thread "ubifs_bgt1_0" started, PID 532
May 5 06:05:12 kernel: jffs2: notice: (1) jffs2_build_xattr_subsystem: complete building xattr subsystem, 0 of xdatum (0 unchecked, 0 orphan) and 0 of xref (0 dead, 0 orphan) found.
May 5 06:05:12 kernel: Loading HND Module
May 5 06:05:12 kernel: crossbar[1]: Add cb_idx=0 ext_ep=0 SERDES:6
May 5 06:05:12 kernel: crossbar Mux: connect cb_idx:0 int_ep 0 to ext_ep 2
May 5 06:05:12 kernel: crossbar Mux: connect cb_idx:0 int_ep 1 to ext_ep 0
May 5 06:05:12 kernel: crossbar[0]: Add cb_idx=0 ext_ep=1 GPHY:12
May 5 06:05:12 kernel: crossbar Mux: connect cb_idx:0 int_ep 0 to ext_ep 1
May 5 06:05:12 kernel: port_generic_open 536 skip turnning on power on eth0 here
May 5 06:05:12 kernel: igs_module_init:867: IGS 18 create network socket successful
May 5 06:05:12 kernel: Cpuidle Host Clock divider is disabled
May 5 06:05:12 kernel: Warning: Setting MAC address of eth0 while it is ifconfig UP
May 5 06:05:12 kernel: dpsta_init: 17.10.99.17 (r780087) 6a04703 Dec 4 2019 14:33:51 msglevel 0x1
May 5 06:05:12 kernel: DHD_FKB_POOL size is:1280 and entry size:2816
May 5 06:05:12 kernel: DHD_PKTTAG POOL size is:2592 and entry size:128
May 5 06:05:12 kernel: PCI_PROBE: bus 1, slot 0,vendor 14E4, device AAA4(good PCI location)
May 5 06:05:12 kernel: dor0: runner supported ring format types TxP 0x5, RxP 0x3 TxC 0x3 RxC 0x3^M
May 5 06:05:12 kernel: dhd_runner_attach: Tx Offload - Enabled, Ring Size = 1024
May 5 06:05:12 kernel: dhd_runner_attach: Rx Offload - Enabled, Ring Size = 1024
May 5 06:05:12 kernel: TX wakeup info: reg = <0x82299004>, val = <0x10000000>
May 5 06:05:12 kernel: RX wakeup info: reg = <0x8229a004>, val = <0x28000000>
May 5 06:05:12 kernel: dhd_attach(): thread:dhd_watchdog_thread:2f4 started
May 5 06:05:12 kernel: Creating CPU ring for queue number 0 with 1024 packets descriptor=0xffffffbffc54a900
May 5 06:05:12 kernel: Creating CPU ring for queue number 1 with 1024 packets descriptor=0xffffffbffc54a940
May 5 06:05:12 kernel: ^[[1m^[[34m wfd_bind: Dev eth%d wfd_idx 0 wl_radio_idx 0 Type fkb configured WFD thread wfd0-thrd minQId/maxQId (8/9), status (0) qmask 0x3^[[0m
May 5 06:05:12 kernel: Instantiating WFD 0 thread
May 5 06:05:12 kernel: dor0: MSG Ring format set to 1
May 5 06:05:12 kernel: dhd_runner_flowmgr_init: dhd0_rnr bootmem addr<ffffffc00a600000> size<14680064>
May 5 06:05:12 kernel: dhd_runner_profile_init: N+M profile = 3 01:1024/1024 -1:2048/2048 -1:1024/1024 -1:0512/0512 00:0512/0512
May 5 06:05:12 kernel: dhd_runner_policy_init: N+M Policy = 0 1 (HW)
May 5 06:05:12 kernel: ^[[0;33;40mRunner DHD PCIE: vendor<0x14e4> device<0xaaa4> bus<1> slot<0>^[[0m
May 5 06:05:12 kernel: Initial configuration
May 5 06:05:12 kernel: =================================
May 5 06:05:12 kernel: rx_post_flow_ring_base_addr : ffffffc02f30a000
May 5 06:05:12 kernel: tx_post_flow_ring_base_addr : ffffffc00a5d8000
May 5 06:05:12 kernel: rx_complete_flow_ring_base_addr : ffffffc02f31e000
May 5 06:05:12 kernel: tx_complete_flow_ring_base_addr : ffffffc02f31c000
May 5 06:05:12 kernel: r2d_wr_arr_base_addr : ffffff80012b5000
May 5 06:05:12 kernel: d2r_rd_arr_base_addr : ffffff80012b5802
May 5 06:05:12 kernel: r2d_rd_arr_base_addr : ffffff80012b6000
May 5 06:05:12 kernel: d2r_wr_arr_base_addr : ffffff80012b5c02
May 5 06:05:12 kernel: tx_post_mgmt_arr_base_addr : ffffff80012b6800
May 5 06:05:12 kernel: tx_post_mgmt_arr_base_phys_addr : 0x2f231800
May 5 06:05:12 kernel: r2d_wr_arr_base_phys_addr : 0x2f230000
May 5 06:05:12 kernel: d2r_rd_arr_base_phys_addr : 0x2f230802
May 5 06:05:12 kernel: r2d_rd_arr_base_phys_addr : 0x2f231000
May 5 06:05:12 kernel: d2r_wr_arr_base_phys_addr : 0x2f230c02
May 5 06:05:12 kernel: Doorbell Post Wakeup register : phy_addr: 0xe0802160, virt_addr: ffffff80012c2160
May 5 06:05:12 kernel: Doorbell Complete Wakeup register : phy_addr: 0xe0802164, virt_addr: ffffff80012c2164
May 5 06:05:12 kernel: Doorbell ISR : ffffffbffc684da8
May 5 06:05:12 kernel: Doorbell CTX : ffffffc02f21bc00
May 5 06:05:12 kernel: flow_ring_format : 1
May 5 06:05:12 kernel: idma_active : 1
May 5 06:05:12 kernel: Backup queue configuration:
May 5 06:05:12 kernel: ========================================
May 5 06:05:12 kernel: Base virt address = ffffffc00df00000, physical address = DF00000
May 5 06:05:12 kernel: Index stack virt address = ffffffc00dfe38c0, physical address = DFE38C0
May 5 06:05:12 kernel: Backup queue entries: total = 58250 shared by all radios
May 5 06:05:12 kernel: Creating CPU ring for queue number 7 with 128 packets descriptor=0xffffffbffc2ca300, size_of_entry 16
May 5 06:05:12 kernel: Done initializing Ring 7 Base=0xffffff80003e3000 End=0xffffff80003e3800 calculated entries= 128 RDD Base=3e012000K descriptor=0xffffffbffc2ca300
May 5 06:05:12 kernel: ^[[0;33;40mRunner DHD Offload initialization complete^[[0m
May 5 06:05:12 kernel: Dongle Host Driver, version 17.10.99.17 (r780087)
May 5 06:05:12 kernel: Compiled in drivers/net/wireless/bcmdhd
May 5 06:05:12 kernel: wfd_registerdevice Successfully registered dev eth6 ifidx 0 wfd_idx 0
May 5 06:05:12 kernel: Register interface [eth6] MAC: d4:5d:64:a4:6a:10
May 5 06:05:12 kernel: dor1: runner supported ring format types TxP 0x5, RxP 0x3 TxC 0x3 RxC 0x3^M
May 5 06:05:12 kernel: TX wakeup info: reg = <0x82299004>, val = <0x11000000>
May 5 06:05:12 kernel: RX wakeup info: reg = <0x8229a004>, val = <0x29000000>
May 5 06:05:12 kernel: dhd_attach(): thread:dhd_watchdog_thread:2fb started
May 5 06:05:12 kernel: Creating CPU ring for queue number 2 with 1024 packets descriptor=0xffffffbffc54a980
May 5 06:05:12 kernel: Creating CPU ring for queue number 3 with 1024 packets descriptor=0xffffffbffc54a9c0
May 5 06:05:12 kernel: ^[[1m^[[34m wfd_bind: Dev eth%d wfd_idx 1 wl_radio_idx 1 Type fkb configured WFD thread wfd1-thrd minQId/maxQId (10/11), status (0) qmask 0xc^[[0m
May 5 06:05:12 kernel: Instantiating WFD 1 thread
May 5 06:05:12 kernel: dor1: MSG Ring format set to 1
May 5 06:05:12 kernel: dhd_runner_flowmgr_init: dhd1_rnr bootmem addr<ffffffc009800000> size<14680064>
May 5 06:05:12 kernel: rx_post_flow_ring_base_addr : ffffffc02e426000
May 5 06:05:12 kernel: tx_post_flow_ring_base_addr : ffffffc0097d8000
May 5 06:05:12 kernel: rx_complete_flow_ring_base_addr : ffffffc02e42a000
May 5 06:05:12 kernel: tx_complete_flow_ring_base_addr : ffffffc02e428000
May 5 06:05:12 kernel: r2d_wr_arr_base_addr : ffffff80012d9000
May 5 06:05:12 kernel: d2r_rd_arr_base_addr : ffffff80012d9802
May 5 06:05:12 kernel: r2d_rd_arr_base_addr : ffffff80012da000
May 5 06:05:12 kernel: d2r_wr_arr_base_addr : ffffff80012d9c02
May 5 06:05:12 kernel: tx_post_mgmt_arr_base_addr : ffffff80012da800
May 5 06:05:12 kernel: tx_post_mgmt_arr_base_phys_addr : 0x2e9d9800
May 5 06:05:12 kernel: r2d_wr_arr_base_phys_addr : 0x2e9d8000
May 5 06:05:12 kernel: d2r_rd_arr_base_phys_addr : 0x2e9d8802
May 5 06:05:12 kernel: r2d_rd_arr_base_phys_addr : 0x2e9d9000
May 5 06:05:12 kernel: d2r_wr_arr_base_phys_addr : 0x2e9d8c02
May 5 06:05:12 kernel: Doorbell Post Wakeup register : phy_addr: 0xc0802160, virt_addr: ffffff80012d2160
May 5 06:05:12 kernel: Doorbell Complete Wakeup register : phy_addr: 0xc0802164, virt_addr: ffffff80012d2164
May 5 06:05:12 kernel: Doorbell CTX : ffffffc02f24b800
May 5 06:05:12 kernel: Creating CPU ring for queue number 1 with 128 packets descriptor=0xffffffbffc2ca000, size_of_entry 16
May 5 06:05:12 kernel: Done initializing Ring 1 Base=0xffffff80003e4000 End=0xffffff80003e4800 calculated entries= 128 RDD Base=3e013000K descriptor=0xffffffbffc2ca000
May 5 06:05:12 kernel: wfd_registerdevice Successfully registered dev eth7 ifidx 0 wfd_idx 1
May 5 06:05:12 kernel: Register interface [eth7] MAC: d4:5d:64:a4:6a:14
May 5 06:05:12 kernel: dor2: runner supported ring format types TxP 0x5, RxP 0x3 TxC 0x3 RxC 0x3^M
May 5 06:05:12 kernel: TX wakeup info: reg = <0x82299004>, val = <0x12000000>
May 5 06:05:12 kernel: RX wakeup info: reg = <0x8229a004>, val = <0x2a000000>
May 5 06:05:12 kernel: dhd_attach(): thread:dhd_watchdog_thread:302 started
May 5 06:05:12 kernel: Creating CPU ring for queue number 4 with 1024 packets descriptor=0xffffffbffc54aa00
May 5 06:05:12 kernel: Creating CPU ring for queue number 5 with 1024 packets descriptor=0xffffffbffc54aa40
May 5 06:05:12 kernel: ^[[1m^[[34m wfd_bind: Dev eth%d wfd_idx 2 wl_radio_idx 2 Type fkb configured WFD thread wfd2-thrd minQId/maxQId (12/13), status (0) qmask 0x30^[[0m
May 5 06:05:12 kernel: Instantiating WFD 2 thread
May 5 06:05:12 kernel: dor2: MSG Ring format set to 1
May 5 06:05:12 kernel: dhd_runner_flowmgr_init: dhd2_rnr bootmem addr<ffffffc008a00000> size<14680064>
May 5 06:05:12 kernel: rx_post_flow_ring_base_addr : ffffffc02e166000
May 5 06:05:12 kernel: tx_post_flow_ring_base_addr : ffffffc0089d8000
May 5 06:05:12 kernel: rx_complete_flow_ring_base_addr : ffffffc02e16a000
May 5 06:05:12 kernel: tx_complete_flow_ring_base_addr : ffffffc02e168000
May 5 06:05:12 kernel: r2d_wr_arr_base_addr : ffffff80012e2000
May 5 06:05:12 kernel: d2r_rd_arr_base_addr : ffffff80012e2802
May 5 06:05:12 kernel: r2d_rd_arr_base_addr : ffffff80012e3000
May 5 06:05:12 kernel: d2r_wr_arr_base_addr : ffffff80012e2c02
May 5 06:05:12 kernel: tx_post_mgmt_arr_base_addr : ffffff80012e3800
May 5 06:05:12 kernel: tx_post_mgmt_arr_base_phys_addr : 0x2e109800
May 5 06:05:12 kernel: r2d_wr_arr_base_phys_addr : 0x2e108000
May 5 06:05:12 kernel: d2r_rd_arr_base_phys_addr : 0x2e108802
May 5 06:05:12 kernel: r2d_rd_arr_base_phys_addr : 0x2e109000
May 5 06:05:12 kernel: d2r_wr_arr_base_phys_addr : 0x2e108c02
May 5 06:05:12 kernel: Doorbell Post Wakeup register : phy_addr: 0xd0802160, virt_addr: ffffff80012f2160
May 5 06:05:12 kernel: Doorbell Complete Wakeup register : phy_addr: 0xd0802164, virt_addr: ffffff80012f2164
May 5 06:05:12 kernel: Doorbell CTX : ffffffc02e6da400
May 5 06:05:12 kernel: Creating CPU ring for queue number 2 with 128 packets descriptor=0xffffffbffc2ca080, size_of_entry 16
May 5 06:05:12 kernel: Done initializing Ring 2 Base=0xffffff80003e8000 End=0xffffff80003e8800 calculated entries= 128 RDD Base=3e017000K descriptor=0xffffffbffc2ca080
May 5 06:05:12 kernel: wfd_registerdevice Successfully registered dev eth8 ifidx 0 wfd_idx 2
May 5 06:05:12 kernel: Register interface [eth8] MAC: d4:5d:64:a4:6a:18
May 5 06:05:12 kernel: random: init urandom read with 16 bits of entropy available
May 5 06:05:12 kernel: proc_dostring_crashlogsave: crash log filename is /jffs/crashlog.log
May 5 06:05:12 kernel: crashFileSet: log signature invalid !
May 5 06:05:12 kernel: ++++ Powering up USB blocks
May 5 06:05:12 kernel: release usb3 reseting..........
May 5 06:05:12 kernel: hub 1-0:1.0: config failed, hub doesn't have any ports! (err -19)
May 5 06:05:13 nat: apply redirect rules
May 5 06:05:15 kernel: eth2 (Ext switch port: 1) (Logical Port: 9) (phyId: 9) Link UP at 100 mbps full duplex
May 5 06:05:16 kernel: <=== Deactivate Deep Green Mode
May 5 06:05:18 WAN Connection: Ethernet link down.
May 5 06:05:19 acsd: eth6: Selecting 2g band ACS policy
May 5 06:05:20 wlceventd: wlceventd Start...
May 5 06:05:20 GT-AX11000: start https:8443
May 5 06:05:20 GT-AX11000: start httpd:80
May 5 06:05:20 httpd: Generating SSL certificate...80
May 5 06:05:20 avahi-daemon[1285]: WARNING: No NSS support for mDNS detected, consider installing nss-mdns!
May 5 06:05:20 disk monitor: be idle
May 5 06:05:20 NAT Tunnel: AAE Service is stopped
May 5 06:05:20 AAE: AAE Service is started
May 5 06:05:20 jffs2: valid logs(1)
May 5 06:05:20 hour monitor: daemon is starting
May 5 06:05:20 miniupnpd[1329]: version 1.9 started
May 5 06:05:20 miniupnpd[1329]: HTTP listening on port 54630
May 5 06:05:20 miniupnpd[1329]: Listening for NAT-PMP/PCP traffic on port 5351
May 5 06:05:20 Mastiff: init
May 5 06:05:20 lldpd[1361]: cannot get ethtool link information with GLINKSETTINGS (requires 4.9+): Operation not permitted
May 5 06:05:21 avahi-daemon[1285]: Alias name "GT-AX11000" successfully established.
May 5 06:05:22 httpd: Succeed to init SSL certificate...80
May 5 06:05:22 httpd: Succeed to init SSL certificate...8443
May 5 06:05:22 kernel: SCSI subsystem initialized
May 5 06:05:22 modprobe: module scsi_wait_scan not found in modules.dep
May 5 06:05:22 modprobe: module mbcache not found in modules.dep
May 5 06:05:22 modprobe: module jbd not found in modules.dep
May 5 06:05:22 modprobe: module ext3 not found in modules.dep
May 5 06:05:22 modprobe: module ext4 not found in modules.dep
May 5 06:05:22 modprobe: module ext2 not found in modules.dep
May 5 06:05:22 kernel: tfat: loading out-of-tree module taints kernel.
May 5 06:05:22 kernel: crossbar Mux: connect cb_idx:0 int_ep 1 to ext_ep 0
May 5 06:05:22 modprobe: module btusbdrv not found in modules.dep
May 5 06:05:23 kernel: eth0 (Int switch port: 3) (Logical Port: 3) (phyId: 1e) Link UP at 1000 mbps full duplex
May 5 06:05:23 WAN Connection: ISP's DHCP did not function properly.
May 5 06:05:23 acsd: eth6: selected channel spec: 0x1009 (9)
May 5 06:05:23 acsd: eth6: Adjusted channel spec: 0x1009 (9)
May 5 06:05:23 acsd: acs_set_chspec: 0x1009 (9) for reason APCS_INIT
May 5 06:05:23 acsd: eth7: Selecting 5g band ACS policy
May 5 06:05:26 acsd: eth7: selected channel spec: 0xec32 (52/160)
May 5 06:05:26 acsd: eth7: Adjusted channel spec: 0xec32 (52/160)
May 5 06:05:26 acsd: acs_set_chspec: 0xec32 (52/160) for reason APCS_INIT
May 5 06:05:26 kernel: random: nonblocking pool is initialized
May 5 06:05:26 acsd: eth8: Selecting 5g band ACS policy
May 5 06:05:26 acsd: acs_candidate_score_intf(1003): eth8: intf check failed for chanspec: 0xe06a (100/80)
May 5 06:05:26 acsd: acs_candidate_score_bgnoise(1305): eth8: bgnoise check failed for chanspec: 0xe06a (100/80)
May 5 06:05:26 acsd: acs_candidate_score_txop(1552): eth8: txop check failed for chanspec: 0xe06a
May 5 06:05:26 acsd: acs_candidate_score_cns(1392): eth8: knoise check failed for chanspec: 0xe06a
May 5 06:05:26 acsd: acs_candidate_score_intf(1003): eth8: intf check failed for chanspec: 0xe16a (104/80)
May 5 06:05:26 acsd: acs_candidate_score_bgnoise(1305): eth8: bgnoise check failed for chanspec: 0xe16a (104/80)
May 5 06:05:26 acsd: acs_candidate_score_txop(1552): eth8: txop check failed for chanspec: 0xe16a
May 5 06:05:26 acsd: acs_candidate_score_cns(1392): eth8: knoise check failed for chanspec: 0xe16a
May 5 06:05:26 acsd: acs_candidate_score_intf(1003): eth8: intf check failed for chanspec: 0xe26a (108/80)
May 5 06:05:26 acsd: acs_candidate_score_bgnoise(1305): eth8: bgnoise check failed for chanspec: 0xe26a (108/80)
May 5 06:05:26 acsd: acs_candidate_score_txop(1552): eth8: txop check failed for chanspec: 0xe26a
May 5 06:05:26 acsd: acs_candidate_score_cns(1392): eth8: knoise check failed for chanspec: 0xe26a
May 5 06:05:26 acsd: acs_candidate_score_intf(1003): eth8: intf check failed for chanspec: 0xe36a (112/80)
May 5 06:05:26 acsd: acs_candidate_score_bgnoise(1305): eth8: bgnoise check failed for chanspec: 0xe36a (112/80)
May 5 06:05:26 acsd: acs_candidate_score_txop(1552): eth8: txop check failed for chanspec: 0xe36a
May 5 06:05:26 acsd: acs_candidate_score_cns(1392): eth8: knoise check failed for chanspec: 0xe36a
May 5 06:05:26 acsd: eth8: selected channel spec: 0xe06a (100/80)
May 5 06:05:26 acsd: eth8: Adjusted channel spec: 0xe06a (100/80)
May 5 06:05:26 acsd: acs_set_chspec: 0xe06a (100/80) for reason APCS_INIT
May 5 06:05:30 BONDING: option disabled
May 5 06:05:50 kernel: ubi1: attaching mtd10
May 5 06:05:50 kernel: ubi1: scanning is finished
May 5 06:05:50 kernel: ubi1: attached mtd10 (name "misc1", size 8 MiB)
May 5 06:05:50 kernel: ubi1: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
May 5 06:05:50 kernel: ubi1: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
May 5 06:05:50 kernel: ubi1: VID header offset: 2048 (aligned 2048), data offset: 4096
May 5 06:05:50 kernel: ubi1: good PEBs: 64, bad PEBs: 0, corrupted PEBs: 0
May 5 06:05:50 kernel: ubi1: user volume: 1, internal volumes: 1, max. volumes count: 128
May 5 06:05:50 kernel: ubi1: max/mean erase counter: 5/2, WL threshold: 4096, image sequence number: 1091345526
May 5 06:05:50 kernel: ubi1: available PEBs: 0, total reserved PEBs: 64, PEBs reserved for bad PEB handling: 4
May 5 06:05:50 kernel: ubi1: background thread "ubi_bgt1d" started, PID 1640
May 5 06:05:51 kernel: ubi: mtd10 is already attached to ubi1
May 5 06:05:51 kernel: UBIFS (ubi1:0): background thread "ubifs_bgt1_0" started, PID 1689
May 5 06:05:51 kernel: UBIFS (ubi1:0): UBIFS: mounted UBI device 1, volume 0, name "nvram"
May 5 06:05:51 kernel: UBIFS (ubi1:0): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
May 5 06:05:51 kernel: UBIFS (ubi1:0): FS size: 5840896 bytes (5 MiB, 46 LEBs), journal size 1396736 bytes (1 MiB, 11 LEBs)
May 5 06:05:51 kernel: UBIFS (ubi1:0): reserved for root: 0 bytes (0 KiB)
May 5 06:05:51 kernel: UBIFS (ubi1:0): media format: w4/r0 (latest is w4/r0), UUID 92D70055-D40E-4496-A698-DA48D5E57B93, small LPT model
May 5 06:06:20 kernel: UBIFS (ubi1:0): un-mount UBI device 1
May 5 06:06:20 kernel: UBIFS (ubi1:0): background thread "ubifs_bgt1_0" stops
May 5 06:06:20 kernel: ubi1: detaching mtd10
May 5 06:06:20 kernel: ubi1: mtd10 is detached
May 5 06:06:28 kernel: bcm_i2c: bus 0: Failed to detect SFP: 100 retries exhausted
May 5 06:06:29 wlceventd: wlceventd_proc_event(527): eth7: Assoc F4
B:E3:28:47:F7, status: Successful (0)
May 5 06:06:39 wlceventd: wlceventd_proc_event(527): eth8: Assoc 14:F6
8:B3
5
F, status: Successful (0)
May 5 06:07:20 hour monitor: ntp sync fail, will retry after 120 sec
May 5 06:08:05 wlceventd: wlceventd_proc_event(481): eth7: Disassoc F4
B:E3:28:47:F7, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8)
May 5 06:09:20 hour monitor: ntp sync fail, will retry after 120 sec
May 5 06:11:20 hour monitor: ntp sync fail, will retry after 120 sec
May 5 06:13:20 hour monitor: ntp sync fail, will retry after 120 sec
May 5 06:15:20 hour monitor: ntp sync fail, will retry after 120 sec
May 5 06:16:43 rc_service: udhcpc 2899:notify_rc start_dhcp6c
May 5 06:16:43 modprobe: module ip6t_REJECT not found in modules.dep
May 5 06:16:43 modprobe: module ip6t_ROUTE not found in modules.dep
May 5 06:16:43 modprobe: module ip6t_LOG not found in modules.dep
May 5 06:16:43 nat: apply nat rules (/tmp/nat_rules_eth0_eth0)
May 5 06:16:43 wan: finish adding multi routes
May 5 06:16:44 miniupnpd[1329]: shutting down MiniUPnPd
May 5 06:16:44 miniupnpd[2980]: version 1.9 started
May 5 06:16:44 miniupnpd[2980]: HTTP listening on port 60319
May 5 06:16:44 miniupnpd[2980]: Listening for NAT-PMP/PCP traffic on port 5351
May 5 06:16:47 WAN Connection: WAN was restored.
May 5 06:16:49 ntp: start NTP update
anyone able to tell me whats going on here? The date is wrong and everything.
this is the logs after the ones before
Aug 7 02:24:43 rc_service: ntp 2964:notify_rc restart_diskmon
Aug 7 02:24:43 disk_monitor: Finish
Aug 7 02:24:43 disk monitor: be idle
Aug 7 02:24:43 start_ddns: update WWW.ASUS.COM dyndns, wan_unit 0
Aug 7 02:24:43 ddns update: ez-ipupdate: starting...
Aug 7 02:24:43 ddns update: asus_private() interface =eth0
Aug 7 02:24:43 ddns update: g_asus_ddns_mode == 2
Aug 7 02:24:43 watchdog: start ddns.
Aug 7 02:24:43 rc_service: watchdog 1267:notify_rc restart_ddns
Aug 7 02:24:44 ddns update: connected to nwsrv-ns1.asus.com (52.250.42.40) on port 443.
Aug 7 02:24:44 ddns update: Asus update entry:: return: HTTP/1.1 200 OK^M Date: Fri, 07 Aug 2020 01:24:44 GMT^M Server: Apache/2.4.29 (Ubuntu)^M Content-Length: 0^M Connection: close^M Content-Type: text/html; charset=UTF-8^M ^M
Aug 7 02:24:44 ddns update: retval= 0, ddns_return_code (,200)
Aug 7 02:24:44 ddns update: asusddns_update: 0
Aug 7 02:24:44 ddns: ddns update ok
Aug 7 02:24:44 ddns update: exit_main
Aug 7 02:24:47 kernel: SHN Release Version: 2.0.1 4b635f32
Aug 7 02:24:47 kernel: UDB Core Version: 0.2.18
Aug 7 02:24:47 kernel: sizeof forward pkt param = 280
Aug 7 02:24:47 kernel: The For ALL DEVICES flag of Prof 2 has been set to ENABLE
Aug 7 02:24:47 BWDPI: fun bitmap = 4ff
Aug 7 02:24:47 kernel: The For ALL DEVICES flag of Prof 1 has been set to ENABLE
Aug 7 02:24:49 A.QoS: qos_count=0, qos_check=0
Aug 7 02:24:50 dhcp6 client: bound prefix 2a02:c7f:d01a:b500::/56
Aug 7 02:24:52 modprobe: module ip6t_REJECT not found in modules.dep
Aug 7 02:24:52 modprobe: module ip6t_ROUTE not found in modules.dep
Aug 7 02:24:52 modprobe: module ip6t_LOG not found in modules.dep
Aug 7 02:24:52 nat: apply nat rules (/tmp/nat_rules_eth0_eth0)
Aug 7 02:24:52 dhcp client: bound 94.192.233.78/255.255.252.0 via 94.192.232.1 for 3600 seconds.
Aug 7 02:24:53 crond[1256]: time disparity of 1187768 minutes detected
Aug 7 02:25:13 hour monitor: ntp sync fail, will retry after 120 sec
Aug 7 02:26:13 WATCHDOG: [FAUPGRADE][auto_firmware_check
6354)]periodic_check AM 2:0
Aug 7 02:26:16 WATCHDOG: [FAUPGRADE][auto_firmware_check
6384)]retrieve firmware information
6401)]no need to upgrade firmware
Aug 7 02:26:19 rc_service: rc 4131:notify_rc restart_wrs
Aug 7 02:26:22 kernel: The For ALL DEVICES flag of Prof 1 has been set to ENABLE
Aug 7 02:26:22 BWDPI: fun bitmap = 4ff
Aug 7 02:26:22 A.QoS: qos_count=0, qos_check=0
Aug 7 02:56:51 acsd: acs_set_chspec: 0x1004 (4) for reason APCS_CSTIMER
Aug 7 02:56:52 acsd: eth6: selected_chspec is 0x1004 (4)
Aug 7 02:56:52 acsd: eth6: Adjusted channel spec: 0x1004 (4)
Aug 7 02:56:52 acsd: eth6: selected channel spec: 0x1004 (4)
Aug 7 02:56:53 acsd: eth6: selected_chspec is 0x1004 (4)
Aug 7 02:56:53 acsd: eth6: Adjusted channel spec: 0x1004 (4)
Aug 7 02:56:53 acsd: eth6: selected channel spec: 0x1004 (4)
Aug 7 03:00:43 disk_monitor: Got SIGALRM...
Aug 7 03:23:41 WAN Connection: ISP's DHCP did not function properly.
Aug 7 03:23:41 nat: apply redirect rules
Aug 7 03:23:43 rc_service: udhcpc 11594:notify_rc start_dhcp6c
Aug 7 03:23:43 modprobe: module ip6t_REJECT not found in modules.dep
Aug 7 03:23:43 modprobe: module ip6t_ROUTE not found in modules.dep
Aug 7 03:23:43 modprobe: module ip6t_LOG not found in modules.dep
Aug 7 03:23:43 nat: apply nat rules (/tmp/nat_rules_eth0_eth0)
Aug 7 03:23:43 wan: finish adding multi routes
Aug 7 03:23:43 miniupnpd[2980]: shutting down MiniUPnPd
Aug 7 03:23:43 miniupnpd[11659]: version 1.9 started
Aug 7 03:23:43 miniupnpd[11659]: HTTP listening on port 48595
Aug 7 03:23:43 miniupnpd[11659]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 7 03:23:43 start_ddns: update WWW.ASUS.COM dyndns, wan_unit 0
Aug 7 03:23:43 ddns update: ez-ipupdate: starting...
Aug 7 03:23:43 ddns update: asus_private() interface =eth0
Aug 7 03:23:43 ddns update: g_asus_ddns_mode == 2
Aug 7 03:23:43 ddns update: connected to nwsrv-ns1.asus.com (52.250.42.40) on port 443.
Aug 7 03:23:44 ddns update: Asus update entry:: return: HTTP/1.1 200 OK^M Date: Fri, 07 Aug 2020 02:23:44 GMT^M Server: Apache/2.4.29 (Ubuntu)^M Content-Length: 0^M Connection: close^M Content-Type: text/html; charset=UTF-8^M ^M
Aug 7 03:23:44 ddns update: retval= 0, ddns_return_code (,200)
Aug 7 03:23:44 ddns update: asusddns_update: 0
Aug 7 03:23:44 ddns: ddns update ok
Aug 7 03:23:44 ddns update: exit_main
Aug 7 03:23:47 WAN Connection: WAN was restored.
Aug 7 03:23:47 kernel: The For ALL DEVICES flag of Prof 1 has been set to ENABLE
Aug 7 03:23:47 BWDPI: fun bitmap = 4ff
Aug 7 03:23:47 A.QoS: qos_count=0, qos_check=0
Aug 7 03:23:50 modprobe: module ip6t_REJECT not found in modules.dep
Aug 7 03:23:50 modprobe: module ip6t_ROUTE not found in modules.dep
Aug 7 03:23:50 modprobe: module ip6t_LOG not found in modules.dep
Aug 7 03:23:50 nat: apply nat rules (/tmp/nat_rules_eth0_eth0)
Aug 7 03:23:50 dhcp client: bound 5.67.25.226/255.255.252.0 via 5.67.24.1 for 3600 seconds.
Aug 7 03:23:56 dhcp6 client: bound prefix 2a02:c7f:d02b:8d00::/56
Aug 7 03:26:53 acsd: eth6: selected_chspec is 0x1009 (9)
Aug 7 03:26:53 acsd: eth6: Adjusted channel spec: 0x1009 (9)
Aug 7 03:26:53 acsd: eth6: selected channel spec: 0x1009 (9)
Aug 7 03:41:58 acsd: acs_set_chspec: 0x1005 (5) for reason APCS_CSTIMER
Aug 7 03:41:59 acsd: eth6: selected_chspec is 0x1005 (5)
Aug 7 03:41:59 acsd: eth6: Adjusted channel spec: 0x1005 (5)
Aug 7 03:41:59 acsd: eth6: selected channel spec: 0x1005 (5)
Aug 7 03:42:00 acsd: eth6: selected_chspec is 0x1005 (5)
Aug 7 03:42:00 acsd: eth6: Adjusted channel spec: 0x1005 (5)
Aug 7 03:42:00 acsd: eth6: selected channel spec: 0x1005 (5)
Aug 7 03:57:05 acsd: acs_set_chspec: 0x1009 (9) for reason APCS_CSTIMER
Aug 7 04:10:42 acsd: eth6: selected_chspec is 0x1008 (8)
Aug 7 04:10:42 acsd: eth6: Adjusted channel spec: 0x1008 (8)
Aug 7 04:10:42 acsd: eth6: selected channel spec: 0x1008 (8)
Aug 7 04:10:43 acsd: eth6: selected_chspec is 0x1008 (8)
Aug 7 04:10:43 acsd: eth6: Adjusted channel spec: 0x1008 (8)
Aug 7 04:10:43 acsd: eth6: selected channel spec: 0x1008 (8)
Aug 7 04:10:44 acsd: eth6: selected_chspec is 0x1008 (8)
Aug 7 04:10:44 acsd: eth6: Adjusted channel spec: 0x1008 (8)
Aug 7 04:10:44 acsd: eth6: selected channel spec: 0x1008 (8)
Aug 7 04:10:45 acsd: eth6: selected_chspec is 0x1008 (8)
Aug 7 04:10:45 acsd: eth6: Adjusted channel spec: 0x1008 (8)
Aug 7 04:10:45 acsd: eth6: selected channel spec: 0x1008 (8)
Aug 7 04:22:48 WAN Connection: ISP's DHCP did not function properly.
Aug 7 04:22:48 nat: apply redirect rules
Aug 7 04:22:49 rc_service: udhcpc 19560:notify_rc start_dhcp6c
Aug 7 04:22:49 modprobe: module ip6t_REJECT not found in modules.dep
Aug 7 04:22:49 modprobe: module ip6t_ROUTE not found in modules.dep
Aug 7 04:22:49 modprobe: module ip6t_LOG not found in modules.dep
Aug 7 04:22:49 nat: apply nat rules (/tmp/nat_rules_eth0_eth0)
Aug 7 04:22:49 wan: finish adding multi routes
Aug 7 04:22:49 miniupnpd[11659]: shutting down MiniUPnPd
Aug 7 04:22:49 miniupnpd[19626]: version 1.9 started
Aug 7 04:22:49 miniupnpd[19626]: HTTP listening on port 36631
Aug 7 04:22:49 miniupnpd[19626]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 7 04:22:49 start_ddns: update WWW.ASUS.COM dyndns, wan_unit 0
Aug 7 04:22:49 ddns update: ez-ipupdate: starting...
Aug 7 04:22:49 ddns update: asus_private() interface =eth0
Aug 7 04:22:49 ddns update: g_asus_ddns_mode == 2
Aug 7 04:22:50 WAN Connection: WAN was restored.
Aug 7 04:22:50 ddns update: connected to nwsrv-ns1.asus.com (52.250.42.40) on port 443.
Aug 7 04:22:50 ddns update: Asus update entry:: return: HTTP/1.1 200 OK^M Date: Fri, 07 Aug 2020 03:22:50 GMT^M Server: Apache/2.4.29 (Ubuntu)^M Content-Length: 0^M Connection: close^M Content-Type: text/html; charset=UTF-8^M ^M
Aug 7 04:22:50 ddns update: retval= 0, ddns_return_code (,200)
Aug 7 04:22:50 ddns update: asusddns_update: 0
Aug 7 04:22:50 ddns: ddns update ok
Aug 7 04:22:50 ddns update: exit_main
Aug 7 04:22:54 kernel: The For ALL DEVICES flag of Prof 1 has been set to ENABLE
Aug 7 04:22:54 BWDPI: fun bitmap = 4ff
Aug 7 04:22:54 A.QoS: qos_count=0, qos_check=0
Aug 7 04:22:57 modprobe: module ip6t_REJECT not found in modules.dep
Aug 7 04:22:57 modprobe: module ip6t_ROUTE not found in modules.dep
Aug 7 04:22:57 modprobe: module ip6t_LOG not found in modules.dep
Aug 7 04:22:57 nat: apply nat rules (/tmp/nat_rules_eth0_eth0)
Aug 7 04:22:57 dhcp client: bound 94.3.220.53/255.255.252.0 via 94.3.220.1 for 3600 seconds.
Aug 7 04:23:03 dhcp6 client: bound prefix 2a02:c7f:d02b:c200::/56
Aug 7 04:25:50 acsd: acs_set_chspec: 0x1004 (4) for reason APCS_CSTIMER
Aug 7 04:25:51 acsd: eth6: selected_chspec is 0x1004 (4)
Aug 7 04:25:51 acsd: eth6: Adjusted channel spec: 0x1004 (4)
Aug 7 04:25:51 acsd: eth6: selected channel spec: 0x1004 (4)
Aug 7 04:25:52 acsd: eth6: selected_chspec is 0x1004 (4)
Aug 7 04:25:52 acsd: eth6: Adjusted channel spec: 0x1004 (4)
Aug 7 04:25:52 acsd: eth6: selected channel spec: 0x1004 (4)
Aug 7 04:40:57 acsd: acs_set_chspec: 0x1007 (7) for reason APCS_CSTIMER
Aug 7 04:40:58 acsd: eth6: selected_chspec is 0x1007 (7)
Aug 7 04:40:58 acsd: eth6: Adjusted channel spec: 0x1007 (7)
Aug 7 04:40:58 acsd: eth6: selected channel spec: 0x1007 (7)
Aug 7 04:56:02 acsd: acs_set_chspec: 0x1009 (9) for reason APCS_CSTIMER
Aug 7 04:56:03 acsd: eth6: selected_chspec is 0x1009 (9)
Aug 7 04:56:03 acsd: eth6: Adjusted channel spec: 0x1009 (9)
Aug 7 04:56:03 acsd: eth6: selected channel spec: 0x1009 (9)
Aug 7 04:56:04 acsd: eth6: selected_chspec is 0x1009 (9)
Aug 7 04:56:04 acsd: eth6: Adjusted channel spec: 0x1009 (9)
Aug 7 04:56:04 acsd: eth6: selected channel spec: 0x1009 (9)
Aug 7 05:24:30 acsd: eth6: selected_chspec is 0x1005 (5)
Aug 7 05:24:30 acsd: eth6: Adjusted channel spec: 0x1005 (5)
Aug 7 05:24:30 acsd: eth6: selected channel spec: 0x1005 (5)
Aug 7 05:24:31 acsd: eth6: selected_chspec is 0x1005 (5)
Aug 7 05:24:31 acsd: eth6: Adjusted channel spec: 0x1005 (5)
Aug 7 05:24:31 acsd: eth6: selected channel spec: 0x1005 (5)
Aug 7 05:24:32 acsd: eth6: selected_chspec is 0x1005 (5)
Aug 7 05:24:32 acsd: eth6: Adjusted channel spec: 0x1005 (5)
Aug 7 05:24:32 acsd: eth6: selected channel spec: 0x1005 (5)
Aug 7 05:24:33 acsd: eth6: selected_chspec is 0x1005 (5)
Aug 7 05:24:33 acsd: eth6: Adjusted channel spec: 0x1005 (5)
Aug 7 05:24:33 acsd: eth6: selected channel spec: 0x1005 (5)
Aug 7 05:39:37 acsd: acs_set_chspec: 0x1009 (9) for reason APCS_CSTIMER
Aug 7 05:53:00 acsd: eth6: selected_chspec is 0x1003 (3)
Aug 7 05:53:00 acsd: eth6: Adjusted channel spec: 0x1003 (3)
Aug 7 05:53:00 acsd: eth6: selected channel spec: 0x1003 (3)
Aug 7 0
Any help would be apprciated.
MC using DQM modeMay 5 06:05:12 kernel: Successfully retrieved NVRAM data from dtb
4:5D:64:A4:6A:10May 5 06:05:12 kernel: eth2: <Ext sw port: 1> <Logical : 09> PHY_ID <0x0007f009:0x09:On-chip GPHY> MAC
4:5D:64:A4:6A:10May 5 06:05:12 kernel: eth3: <Ext sw port: 2> <Logical : 10> PHY_ID <0x0007f00a:0x0a:On-chip GPHY> MAC
4:5D:64:A4:6A:10May 5 06:05:12 kernel: eth4: <Ext sw port: 3> <Logical : 11> PHY_ID <0x0007f00b:0x0b:On-chip GPHY> MAC
4:5D:64:A4:6A:10May 5 06:05:12 kernel: eth5: <Ext sw port: 7> <Logical : 15> MAC : D4:5D:64:A4:6A:10
B:E3:28:47:F7, status: Successful (0)May 5 06:06:39 wlceventd: wlceventd_proc_event(527): eth8: Assoc 14:F6
8:B3
5
F, status: Successful (0)May 5 06:07:20 hour monitor: ntp sync fail, will retry after 120 sec
B:E3:28:47:F7, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8)May 5 06:08:05 wlceventd: wlceventd_proc_event(481): eth7: Disassoc F4
B:E3:28:47:F7, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8)May 5 06:09:20 hour monitor: ntp sync fail, will retry after 120 sec
6354)]periodic_check AM 2:0Aug 7 02:26:16 WATCHDOG: [FAUPGRADE][auto_firmware_check
6384)]retrieve firmware informationAug 7 02:26:16 WATCHDOG: [FAUPGRADE][auto_firmware_check
6401)]no need to upgrade firmwareAug 7 02:26:19 rc_service: rc 4131:notify_rc restart_wrs
Aug 7 0
