Problems with new GFX/Voltage Questions!
Hey guys, just wanted to double check on this before I put in an RMA!
Ordered an E8400 CPU and XFX 4890 GFX Card this week, to addon to my current system of:
Asus P5N-E SLI
4GB OCZ platinum 6400
1 x SATA 1 HDD, 2 x Samsung F1 750GB, 1 x OCZ SSD 30GB
Corsair Modular PSU 620W
The cpu went in and on fine, running a bit hotter than my E6300, which was a bit of a surprise, but ah well, just to check though, its on stock 3.00ghz @ 1.36Volts.
The graphics card however, seems to have massive distortion, I'm sure I have adequate power from the PSU to run it, but its giving me a totally corrupted screen:
Which is happening no matter what I try, including 4 re-seats of the card and reboots, cmos reset, battery out, CLRTC etc.. and pretty sure its an on card fault.
Does this look RMA worthy to you all? And do you know if OcUK would happen to do refunds/lower swaps (ie: for an Ati 5770?)
Thanks
Asus P5N-E SLI
Thanks
Cpu core temps are the same as yesterday, too.
