Hi
I just upgraded my system to Athlon X2 - Asus A8N-SLi SE mobo - ATI Radeon X800 GTO 512MB - 1Gb Corsair DDR Ram. I kept the same HDD (120gb IDE) for the time being. Previous system was Athlon 2500+.
I expected problems, and here it is:
The system boots up to the Windows XP logo (I have XP Pro - I set the BIOS to the correct settings as far as I can tell) and then just reboots itself all over again (i.e. system reset).
Now I would re-install XP, but i have found my disk is knackered.
From this vague description that I have given can anyone tell what the problem is that may be causing the restarts? In the meantime I'm trying to sneak an XP disk from work...!
