Just received my MSI 7870 Hawk. http://www.overclockers.co.uk/showproduct.php?prodid=GX-162-MS&campaign=pcm/googleshopping
Motherboard will boot with my 4890. Will try to boot once more with the 7870 but I suspect I've been given a dud card. The cover on the heatsink of the HAWK seems slightly bent, as in it dips down instead of being level with the PCI bracket, could just be how they are all made but haven't seen another in the flesh, was first thing I noticed when I opened the box. Except for my haribo...thanks for that.
Any ideas? I have a 600W Be Quiet power supply, this seems very odd! Seems to be the card causing the problems.
System spec:
- Installed it just like my 4890.
- Booted fine.
- Installed drivers, restarted.
- Played Deus Ex for about 5 minutes.
- System unexpectedly just turned off, no noise or bangs, just off.
- No response from trying to boot PC.
- Checked cables, re seated card.
- GPU fans kick, but not response from any part of system.
- Removed battery from motherboard.
- Still wouldn't boot.
- Reinstalled 4890 and works fine.
System spec:
- [email protected] on Noctua D-14 43 idle 55 load
- Gigabyte P35C-DS3R latest firmware etc
- 4GB DDR3
- Spinpoint F3 1TB
- SB Audigy2 ZS
