- 22 Dec 2010
I built a completely new system 2 weeks ago and when i try to load age of empire 3 i get a message- YOU REQUIRE 64MB RAM, YOU ONLY HAVE 0MB AVAILABLE. all my drivers are up to date, including graphics card.
my spec is--
Asus M4A89GTD pro amd 890GX SOCKET 3 DDR3motherboard
AMD PHENOM 2 X6 CORE 1090T BLACK EDITION 3.20GHz
gigabyte nvidia GTX 460
running on 64bit windows xp
also i have loaded gigabyte OC_GURU that came with the grahics card.
and when the system starts i get a message-
Grahics card smart tuner has encountered a problem and needs to close.
this program worked fine when i tryed graphics card in older pc.
i also have a problem when trying to play a blu-ray disc
i have cyberlink power dvd, when i try to play a film,
i press play and the program closes down. it works fine with a DVD.
if anybody can give me any help, i really would apriciate it,
2 weeks of head aches lol,
cheers
my spec is--
cheers
