I have a quite a few domains that I run on a hosting account.
The main domain is www.techmonkeys.co.uk then I have several add on domains one of which is www.swiftpcrepair.co.uk
However it appears the swiftpcrepair.co.uk domain is suddenly not resolving.
I ran a DNS report on www.dnsstuff.com on both Techmonkeys and Swift which are obviously on the same server, using the same nameservers.
When I do this on Swift I get the following errors:
yet there are no such errors when running it on Techmonkeys.co.uk, both are on the same host and use the same name servers.
Anyone have any ideas?
ERROR: One or more of the nameservers listed at the parent servers are not listed as NS records at your nameservers. The problem NS records are:
ns5.catalyst2.net.
ns6.catalyst2.net.
ERROR: You have one or more lame nameservers. These are nameservers that do NOT answer authoritatively for your domain. This is bad; for example, these nameservers may never get updated. The following nameservers are lame:
84.18.207.222
70.84.235.18
