OK, I'm back up and running!
But can I put my finger on exactly what the problem was? No.
However, last night before shutting down I'd basically unplugged everything and reseated. Still nothing. So just as a last thought I twisted my Tunig Tower
slightly from side to side to see if i could move the processor in case it was a bad connection. Hey presto, after reconnecting the power cable and switching on my PC fired up and the PSU stayed on and the discs span up but no BIOS or screen output. However, this was still progress. So tonight, I dismantled everything, took out the mobo, checked just to make sure of no broken tracks or popped capacitors. Reseated the Quad Core and reapplied thermal paste. Refitted my Tuniq Tower
recabled everything (remeber not to fit everything perfect as it may have had to come out if the problem was not sorted) then connected the basics (No printers, scanner, etc) and started it up. ASUS logo came on, went through post, started Vista in safe mode (due to the crash in first place) and went through all fine. Dosconnected and recabled everything and had the chance now to go back and cable properly from the examples I'd seen on OC forum, which now looks really smart. So, the moto to this story is:
"If you think its broken, it not always is, so don't think the worst until you've checked everything!"
I'm now going to sleep!
