Problems with Q-Fan (motherboard fan controller) and 120mm Fan
18 Jun 2003
Southampton UK
Hi, basically my girlfriends cpu fan was slowly starting to annoy me as it was only 70mm and was loud when on full whack!
The fan was controlled by the motherboard using the bios Q-Fan setting this worked fine turning the fan up and down depending on how hot the cpu was.
Now ive changed the fan to a 120mm one it just seems to be on full whack all the time even if I adjust the fan speed manually.
Have i overlooked something simple here?
