Problems with Radeon X800 XL
18 Aug 2007
Hi there,
I bought this card about 1.5 years ago but never installed it as I was saving up for a new PC. Anyway, just put the card into my motherboard and everythings working fine until I installed the drivers for it, as soon as you enter windows the screen pixelates and changes colour then goes black and the card reboots. I've tried the latest drivers. Any ideas?
Every cable is plugged in correctly, I've tried the drivers which came on the CD, plus old drivers off the net. I'm using a 700W PSU so i don't reckon there's a shortage of power.
If you had a prior card installed, especially from Nvidia, did you use drivercleaner to fully remove the older drivers?
Perhaps also try the Omega ATI drivers to see if they are any different.
Buying hardware and not testing it straight away isn't exactly a good idea, especially as you'll have lost a big chunk of the warrenty. Do you have a friend that has a machine you can try the card in?
Yeh, that was my next plan - checking it out on my mates PC. If it doesnt work on his what can I do? I've gone and bloody lost my receipt as well.
