Problems with Sony x95g (NZ) - 4 red blinking lights after switching to HDMI
19 Oct 2002
Auckland, New Zealand
Hi
I've got a Sony Bravia x95G which has recently started to throw an error with the LED light blinking red 4 times after the screen shuts off. This issue is only apparent once switched to HDMI and receiving input from another device, e.g. my Xbox Series X. I use ARC from HDMI 3 to my amplifier and that continues to work fine. Once the screen has gone off, it needs a power cycle to bring back the TV afterwhich it works fine when running normally via Google TV.
I presume this means that something (mainboard?) controlling the HDMI ports is not working correctly? I'm going to try the Nintendo switch and my xbox one x and see if that causes the issue but does anyone know if this is a common fault or something more terminal?
Thanks,
Chris
Ok so the issue also includes all UHD/Dolby Vision content too via apps on Android TV and not just inputs via HDMI.
