Problems with sound when G15 keyboard & Z-10 speakers in pc.
18 Apr 2008
I have used a G15 keyboard for quite a while now with no problems & recently descided to upgrade my speakers system.
I have just bought myself the Z-10 speakers.
The problem I'm having is when both plugged into usb ports on pc speakers sound tinny & base is overpowering, but when I unplug the keyboard from usb & reboot pc speakers work perfectly well.
Tried a normal unlit usb keyboard speakers work perfect, but unfortunately when I plug G15 back in it goes to default on lcd panel & sound is distorted again.
I'm not worried about the lcd panel so much but would like to fix the sound distortion if possible.
My pc specs are :-
OS - Windows XP Build 2600, Service Pack 2
CPU - DualCore AMD Athlon 64 X2 Black Edition 6400+
Motherboard - Asus M2N-SLI Deluxe
Graphics - NVIDIA GeForce 8600 GT (512MB)
Monitor - Maxdata Belinea 22W Artistline
Audio - nVIDIA nForce 570 SLI
Speakers - Logitech Z-10
Keyboard - Logitech G15
Mouse - Razer Lachesis
(put more specs than normal in as mostly connected to pc via usb ports)
Please can anyone advise me on this problem.
Thank You
SAFC
