Man of Honour
- 15 Mar 2004
- Liverpool
I am trying to follow these simple instructions that were posted a while back :
I am however getting these messages when for example I try to find out how much System Restore is currently taking up :
When I then run the other command to resize the space allowed, I get :
Running any other commands specified using the help command result in :
Running this as an administrator doesn't help. The drive in question is active, no errors and is selected for System Restore.
I am using Vista 64 and it's a 3 day old installation.
Open a command prompt in administrator mode,
Type in the following command into the prompt
vssadmin list shadowstorage
This will bring up how much system restore is taking up.
To change the maximum size on the disk that System Restore uses type in the following
vssadmin Resize ShadowStorage /For=C: /On=C: /Maxsize=4GB
I've put in 4GB as an example but you can change that to whatever size you want.
Code:
vssadmin 1.1 - Volume Shadow Copy Service administration command line tool
<C> Copyright blah..
No items found that satisfy the query.
Code:
Error: The specified volume shadow copy storage association was not found.
Code:
