Problems with the 470
20 Oct 2010
Hello guys, i've been testing all day the new card i bought MSI geforce 470 Twin Frozr II and to be honest except the COD4 and codMW2 i didnt see any nice results in the other games i tested compared to my old 8800gts
I'll post some of my fps that i got so far if i had a reading in my 8800gts ill post it also else ill just post the new benches with the 470 (settings depend were the same as when i was playing with the 8800 and resolution is 1920x1200)
COD 4 was 40 fps went to 120-200
CodMW2 went to 88-100
Devil may cry 4 went to 180first scene no AA AF
battlefield bad company 2 became 25-30 fps ( i think its slow)
Brother in arms hell's highway went to 55-70 ( i saw a bench doing 95)
SC2 all maxed in options 50-55 no vsync same as the 8800gts
F12010 is 30fps!! i think is slower than the 8800(didnt wrote it down when it worked)
3dmark06 no patch 13800 (res 1280x1024 it was on default)
3dmark06 with patch 12350 (actually slower than the 8800)
I also notished in the 3dmark test that it went from a stable number of fps for a click of a sec to a really low one and the up again every now and then like from 88 in the first scene to 11 and then back up)...
I run windows xp sp3 i have 3 GB of ram and my E7400 is clocked around 3.2GHz using the EPU-6 engine from asus. I did install the latest drivers ( i tested also the 258 but it couldnt install the hdsound of the card).
Guys what do you think. The 3dmark part was really awfull.. Is it cpu bottleneck? is it the drivers? or something else?
