- 23 May 2012
Due to the lack of availability, I took the risk of purchasing a used Samsung S27A750D. However, I'm having a problem with it, and I'm not sure if the problem is normal.
Out of the box, the monitor has a whitish/greyish hue over the bottom half of the monitor. It clears up at the top. Out of the box, the picture looks terrible.
The hue on the bottom seems to clear up once I turn on Magic Angle. Side view seems to be the best option for Magic Angle. Also, I don't notice much of any light bleed, using a light bleed test, once I turn on Magic Angle.
I just want to know if I should expect strange color distribution like this from a monitor, so that when I get a new one I can know what's actually normal?
Should I be looking for a good picture without magic angle, and then an even better picture with magic angle?
I've already RMA'd it btw.
