- 3 Jan 2009
- Bedfordshire
I have installed it today and i cannot get any fans to work that are plugged into it.
I have got 4 pin molex fans, i brought all the adapters for the fans and plugged them in to FC and still nothing.
The molex power socket does work so i know the FC is getting power.
The ONLY thing it does, it flash its LED'S for a split second when you power the pc.
I wanted to know do the fans require power or does the FC supply the power to the fans. I haven't got a 3 pin fan, i am a bit iffy on whether these adapters are causing problem?
Any advice or things to try would be grand
As im losing the will to live lol
Thanks
Thanks
