transfered my motherboard/cpu/hdd/gpu from my old Antec 900 to a Kandlf LCS with a new 700w Thermaltake PSU, set it all up read the instructions for putting together the LCS.
When i turn it on i get no signal for the monitor, i can hear the harddrives spinning up and all the LED's light up, the pump works same with the GPU fans.
Ive followed some guiding from mates about how to hopefully solve the problem but to no avail,
check connections etc
removed the cmos battery waited 2mins
removed the cmos battery & ram & power cable waited 2mins
thing is it was all working in my 900 this morning so i dont see why it wouldnt work now.
E6600
P5w DH Deluxe
4Gb DDR2 800
3870XT
hmm i have a G15 that doesnt light up when the powers turned on also theres no 4pin connector from the PSU to Motherboard.
E6600
P5w DH Deluxe
4Gb DDR2 800
3870XT
