Procedure for nvidia upgrade
sid
sid
9 Feb 2003
London
Going from a 8800gts to 260gtx
Going to uninstall drivers - restart - then shutdown when it prompts to reinstall drivers again.
Then swap gfx and restart - install new drivers?
I hope there wont be any issues.
I've got a IP35 Pro board here
sid
In normal Windows, uninstall through add/remove (or whatever program you might use to do so).
-Reboot into safe mode.
-Run Driver Cleaner for "Nvidia" selection in the drop down box, ONLY "Nvidia"
-Shutdown, card swap.
-Boot into safe mode.
-Install new drivers.
-Reboot into normal Windows.
If you cannot be bothered to use Driver Cleaner, then follow the other steps, just remove that part.
Yeah driver cleaner im hoping wont be needed due to it being a be nvidia to nvdia upgrade.
sid
