)Here is a building guide by corsair. use the drop down list at the bottem to move to the next page (took me a while to find it lol)
http://tools.corsair.com/systembuild/report.aspx?report_id=78237&sid=1
It's certainly the most fiddly part. You need good eye site as well!Hows it going? You got to the wireing up the buttons on the case? I think its the hardest and most frustrating bit lol.
yeah thats were i got them aginst the case between the raised screw... but the screw still fastens to the case metal to metal so how does that bit help :-S ??
Nice one, that will help me. I can't wait till I start building.
. Ive yet to see a mushroom cloud so you must be doing well!
Keeps the mobo off the case.
Your sig is to long believe its 4 or 5 lines deap max. Youll get it deleated by the admins and then you gota do it again. When they updated the forum my sig randomly switched its self to all on one line. Then tey deleated it before i got chance to edit it grrrrr.
And no prob about the guide. Its pretty good.
