cyborg said:Its called TIM clean, I know that a nationwide electronics store stocks it.
Tetras said:
http://www.overclockers.co.uk/acatalog/Thermal_Materials.html
ArctiClean Thermal Material Remover and Surface Purifier - 60ml Kit (TH-000-AC)
£5.82 (inc VAT)
Akasa TIM Clean CPU & Heatsink Cleaner (OA-001-AK)
£6.99 (inc VAT)
Yes good old IPA, get it also at any pharmacyGhuraba said:You can use Isopropyl Alcohol. Electrical shops normally sell it.
Gimpmaster3201 said:Although it is not usually recommended, I've used nail varnish remover that was lying around the house in the past. Most nail varnish remover is said to contain additives, colourings etc... but I've had no problem using it with this CPU that has been running flawlessly for 1-2 years. If you can't be bothered ordering some TIM online or have some nail varnish remover lying around the house i would give that a try.
