Processor upgrade worth it?
21 Sep 2010
Hi all,
I'm updating my ITX mini gaming computer, but wondering whether I can be bothered to do the whole processor motherboard thing.
I currently have a Gigabyte H55N USB3 and i5 750 @ 3.5GHz (resale value ~£100)
Thinking about getting a 2500K or 3570K OC and a Z77 board (upgrade cost at second hand prices, approx £180-200)
Or an i7 860 and keep the motherboard (860s are about £70)
I'm upgrading the cooling in my new case to an AIO water cooler, probably a Corsair H50.
My graphics card is an HD7970.
Option 1: Obviously the cheapest is to keep the same, probably clocked to 3.8GHz, but is the CPU likely to bottleneck the GPU?
Option 2: The next cheapest is to upgrade to an 860, probably around 3.7GHz with hyperthreading (net cost ~ £10). I'm considering this because the latest consoles have 8 processing cores, so more ported games may be able to use the 8 logical cores (with hyperthreading) of the 860 over the 750.
Option 3: Upgrade motherboard and processor to Sandy/Ivy bridge @~4.2GHz. This would cost £80-100 and take the most time. Is it worth it for the overall gaming performance boost?
i'd question if you need to, seems you are happy with your present but want a slightly newer one. why not get the i7 and the AIO and see if that makes a massive difference, it might not do.
otherwise, i'd get a haswell refresh bundle - new, or haswell secondhand.
that said, my pc is coming out of storage soon and it has a ivy 3570k sitting at 4.5 ghz without struggling and i'm pondering a upgrade to haswell refresh or keep for a while and get ddr4 stuff next year.
