Could somebody tell me if this is possible using these switches:
1 Subnet, lots of VLANs.
I.e. all the ports have a machine on the end of them and I want to block communication between the ports on the switch. But at the same time I'd like each port to be able to get an IP from DHCP from a router attached to the switch and then access the internet via said router.
I'm assuming that as I don't need to route between any of the ports/Vlans I can do this at L2 and it should be fairly simple?
I think on Cisco this is called a Private VLAN? Do HP do this or is it one of those proprietary things you don't miss until you can't do it with another vendors hardware?
Not bought/specced these switches yet, but I'm tempted to use them as they are 1/3 of the cost of the Cisco to me, and my client are being very tight with the purse strings!
