Hi All.
I'm having a few troubles with creating an extended acl on a HP Procurve switch
(its a 5406zl if it matters..) to reflect the port requirements as below:
To connect using FileMaker products, please ensure the following ports are open
It's to go on a VLAN used for a Wireless PAN and I've not quite cracked the ACLs.
Any pointers would be appreciated.
Thanks
		Code:
	TCP Port 5003 - OUTBOUND - from ANY local host - to remote IP addresses 193.33.187.85 & 37.26.105.2
TCP Port 16000 - OUTBOUND - from ANY local host - to remote IP addresses 193.33.187.85 & 37.26.105.2It's to go on a VLAN used for a Wireless PAN and I've not quite cracked the ACLs.
Thanks
