- 26 Dec 2013
- 404 Not Found
I'm currently building a Bitfenix Prodigy with a watercooled GPU and CPU off a single 240mm Rad. I have been looking at some 60mm thick low FPI rads so I can keep my fan speeds down. The only problem I have, using a 60mm rad + 25mm thick fans it's going to look a bit squashed, and my main objective is aesthetics.
My total TDP is about 250W. The GPU is rated at 150W and my i5 4670k is overclocked @4.2 GHz. I'm not sure if I could get away using a 30mm rad?
My other thought, but i'm not sure how it would look, is to mount the 60mm thick rad inside the case, then mounted 120mm fans to the top of the case drawing air in through the rad and exhaust at the rear 120/140mm fan.
What are your thoughts and suggestions?
Edit:
My other thought it top externally top mount the rad
Edit:
