Hi,
I've decided my small computer was far too loud so I've decided to start building hard line system. I'm using all the hardware from my old computer plus/minus a few bits.
My new build:
Case: Bitfenix Prodigy M + Clear side panel
Motherboard: Gigabyte H61N-USB3
CPU: i5 4570K 3.2ghz quad core
Memory: Corsair 8GB DDR3 1866Mhz
GPU: GTX 980 4gb
PSU: EVGA 550watt fully modular
SSD: Samsung 845DC EVO 480gb
Water Cooling:
CPU: XSPC RayStorm
GPU: EK-FC980 GTX
Pump: EK-D5 Vario X-TOP
Res: EK x3 110
Radiators: XSPC 240 rad (top), XSPC 120 rad (bottom)
Pipe: Monsoon Hard Acrylic Tube 1/2 x 5/8 -Clear
Fittings: Monsoon Free Center Hardline 1/2 x 5/8 - Purple
Fluid: Mayhem Pastel Orange
So that's my complete build (I think) I have already started the build but I've been taking pictures along the way because it's probably the most difficult build I have ever done.
So I started the build off by removing the HDD mounting panel from the side of the case and taking off the optical drive mounting bay so I had a nice empty case
After clearing out the case I put the waterblock on my GPU to and put my PSU in the case and decided to test to see if it would all fit.
Yeah so apparently my EVGA 750 watt PSU is too big for the build thats the reason that I am going to downsize to the 550 watt still leaving very little room for watercooling.
After testing to see if some parts would fit I went ahead and installed a smaller temp PSU and all of the hardware, rads, pump and res in the only way that I could make them all fit.
At this point I started to regret purchasing the Prodigy m as it is so damn tiny. The pipe work is going to be pretty difficult because it's my first hard pipe build and 2 because of the lack of room that I have.
My plans for the pipes are
From the res into the front of the pump (this pipe will have 4 right angle bends)
From the top of the pump to the top rad (this pipe will have 2 right andle bends)
From the top rad to the bottom left GPU inlet (This pipe will have 2 right angle bends)
From the GPU into the CPU (1 right angle bend)
From the CPU into the bottom rad(1 right angle bend)
From the bottom rad into the res (1 right angle bend + U bend)
I have not started work on the pipes but I should be starting on them this weekend so hopefully should have the build done by next weekend.
I shall keep you all posted with new images as I progress. If you have any questions feel free to ask.
My new build:
GPU: GTX 980 4gb
Water Cooling:
CPU: XSPC RayStorm
GPU: EK-FC980 GTX
Res: EK x3 110
