Prodigy M or prodigy for mitx system
  • Thread starter Thread starter FNG
  • Start date Start date
FNG
FNG
28 Dec 2002
I am putting together a mini itx build and am going with the Prodigy. I was just wondering whether I was better off getting the Prodigy M in case I want to go mAXT in the future, or whether the trade off in the internals made it a much worse case for a mini itx build than the normal Prodigy.
Any thoughts would be much appreciated!
I've built a PC with the original Prodigy and would say that it's a very big case for an ITX build, don't get me wrong I like it as a case and it's very functional just big for an ITX build. Out of the two if you are going ITX I would use the normal Prodigy case and not the Prodigy M as that's really designed for people who want to use an M-atx motherboard the original ITX case will serve you well for an ITX build.
Out of the 2, I'd go with neither of them. Much better Micro ATX cases out there, and the original Prodigy is a ridiculous waste of space if you're not using a tower cooler and lots of hard drives.
What's the spec of your build? I may have better suggestions for you.
