Prodigy or Phenom?
5 Oct 2013
Hey guys,
I'm looking at my first build of a computer soon, and I was all set on the BitFenix Prodigy until they recently released the Phenom.
From what I can see the difference is all in the aesthetics, is that right?
Basically the Phenom has no handles, and no see through side. Are there any other differences I should be aware of?
I'm looking to buy the mini ITX version.
Cheers in advance!
Jack
Phenom has no useable 5 & 1/4 inch bay. Its internal only (god knows why) so you cant use any CD/DVD drive or fan controller that uses the bay.
Hey guys,
Cheers in advance!
Jack
The Prodigy window would only show a GPU,
I've looked at both, the itx version of the prodigy is okay, but i went matx in the end.(i have a 350d Corsair BTW) now, the problem with the prodigy-m is cooling, the gpu would be right next to the radiator if using watercooling (which most people do now)
If your dead set on ITX id look at the phenom, if your okay with not being able to see into it..
It's still far too big for Mini-ITX so I'd go neither.
What components are you using? I recommend the Silverstone Sugo SG05 - I love mine
