Prodigy water cooled
3 Jan 2013
I'm considering water cooling my prodigy case I'm running i5 3570k, gigabyte 7950, as rock z77 and Samsung greens. I'm looking to overclock all components so will need a good cooling system. Will I need two rads or will one be sufficient. Do I buy a kit or seperatly? What do you suggest?
Thanks tom
Thinking of a 240 mm rad at the top then at a later date add a 200mm at the front.
What pumps are quiet? Are the ek kits any good?
Why not a 140 in the back and a 240 up top?
That way you can still stick ya HDD's in :)
AND have room for a MASSIVE 230mm fan in the front for maxi airflow
